Carrier 52CQ-312---4 Comfort Series Heat Pump, 12000BTUH, 3.4KW, 265V PTAC Air Conditioner
Problems with Carrier 52CQ-312---4 Comfort Series Heat Pump,...?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Carrier 52CQ-312---4 Comfort Series Heat...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Carrier 52CQ-312---4 Comfort Series Heat Pump, 12000BTUH, 3.4KW, 265V PTAC Air Conditioner RSS Feed
View More Results for Carrier 52CQ-312---4 Comfort Series Heat Pump, 12000BTUH, 3.4KW, 265V PTAC Air Conditioner
Find a Manual
Carrier 52CQ-312---4 Comfort Series Heat Pump, 12000BTUH, 3.4KW, 265V PTAC Air Conditioner Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Does your A/C coil freeze up?
This is actually something that causes more service calls than actual failures. Those who do not have the knowledge to fix it has to make that dreaded... written by cj2176
You can add Air Conditioning to Your Hot Air Furnace
Air Conditioning is easier to add to an existing central hot air heating system then you might think. Both systems use air to move the heating or... written by heatman101
Old motor has 3 wires, new motor has 4 wires, WTF?
You always want to save a few bucks in these tough times right? Don't want to spend a fortune replacing the motor with the exactamundo. So you... written by TheMobilian
Some central air conditioning unit solutions
outside works inside don't Nothing works Outside quit inside works written by TheMobilian
Air Conditioning Programmable Thermostats - Great for Heating and Cooling
Programmable thermostats contribute to overall system performance, maximizing energy savings while providing complete comfort control. They also allow... written by heatman101
How to Keep House Cool Without Using Air Conditioning
The expense of running the air conditioner is just too much. You open the house doors and windows up to try to cool the house down. But the house just... written by heatman101
outside unit fan replacement tip
Your central unit outside condenser motor is gonna someday die, that's a fact of life, will you pay some guy 450 dollars to replace a 75 dollar part?... written by TheMobilian
Ductless Split Air Conditioner Review
Ductless split air conditioning units are the very best thing for some situations. Of course they can be installed in the place of most any central... written by heatman101
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Carrier 52CQ-312---4 Comfort Series Heat Pump, 12000BTUH,...
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
Rate and Review the Carrier 52CQ-312---4 Comfort Series Heat Pump, 12000BTUH, 3.4KW,...
Write a review:
Rate this product:
Would you recommend the 52CQ-312---4 Comfort Series Heat Pump, 12000BTUH, 3.4KW, 265V PTAC Air Conditioner to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Carrier Contact Information
Main support number1-800-227-7437
Support FAX1-315-432-6620
Describe your problem:
Top Air Conditioners Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
