20 Most Recent Krups XP2010 Espresso Machine & Coffee Maker Questions & Answers
4answers
Water leaking in espresso machine
I have a Krups 2010 and it leaked from day one I used it for about a month before I decided to fix it myself instead of paying for shipping it to them. After opening the back (yes the warranty is broken) I took some photos and here is what I found. Poor quality control there are two screws holding a hose interface to the reservoir and they are not tight or became loose since they are metal screws going into plastic that get hot and vibrates.
The fix is to tighten the screws just slightly so that you do not crack the plastic then dab them with nail polish so that they do not move. (see second photo). This machine still makes one of the best espressos I have tasted and now it is one of the easiest to clean.
10/15/2014 8:33:09 PM • Krups XP2010... • Answered on Oct 15, 2014
How can i open the back panel of the kruos xp2010
To open back side: remove 6 cross screws Sides are now loose but top and bottom are fixed by a plastic flange of 2mm. simply pull the back cover off with fingers hooked on each side, the cover will flex. Otherwise cut the bottom flange with a knive and use some duct tape to fix it later at that spot
4/28/2014 4:40:02 PM • Krups XP2010... • Answered on Apr 28, 2014
0answers
0answers
Hi, I just got the
This was very difficult to locate, but I found it just for you! :) Please rate my answer 4 thumbs up on the site here, it is very important to me. I would be forever grateful. Here is the manual for you, please give it a few minutes to load it's a somewhat large file. If you need it emailed to you please respond back to this post and I will email it over. Here is the manual (you will need adobe reader to view it, but you probably already have that installed):
http://www.krupsusa.com/NR/rdonlyres/B454517D-7214-428F-BE57-932CFACB3E97/7240/XP2010.pdf
10/12/2010 4:30:39 AM • Krups XP2010... • Answered on Oct 12, 2010
XP4020 - n1164
Krups XP 4020 Semi-automatic Espresso Coffee Maker http://www.coffeemachinemanual.com/krups-xp-4020
5/26/2016 6:34:36 AM • Krups XP Coffee... • Answered on May 26, 2016
Where can I get replacement for the two grille plates of my Krups Grille system 2002
are they shorted ? see if thermal blown
3/9/2016 1:27:56 PM • Krups XP Coffee... • Answered on Mar 09, 2016
XP2280. Where can I obtain an owner's manual?
Krups XP1500 Instructions ' eHow
www.ehow.com > Home
Krups XP1500 Instructions. The Krups XP1500 is a coffee machine and espressomaker with a 10-cup coffee capacity, pause and serve feature, non-stick ...
KRUPS XP1500 USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > ... > Coffee Maker > XP1500
Translate this page View and Download Krups XP1500 user manual online. Krups XP1500: User ... Coffee Maker Krups ESPRESSO COMBI XP1600 User Manual. (51 pages).
Krups 867 Instructions For Use Manual - ManualsLib
www.manualslib.com > Brands > Krups Manuals > Coffee Maker > 867
Coffee Maker KRUPS ESPRESSO NOVO 2100 PLUS Instructions For Use Manual ...Coffee Maker Krups XP1500 User Manual ... stronger brew than regular grammablecombination ber to NEVER open the coffee, espresso, and coffee.
1/28/2016 11:25:46 PM • Krups XP Coffee... • Answered on Jan 28, 2016
Hello, I have Krups XP-7220. When I try to make a coffee, machine start to ask me for refilling. And this process is endless.
Check the water float in the tank, it is common for them to cease floating sometimes. Krups solution is a new tank, my solution is to jam something plastic underneath it to lift it up so that it activates the sensor. Even if tank is empty it will no longer ask you to fill it up.
2/6/2015 10:03:59 PM • Krups XP Coffee... • Answered on Feb 06, 2015
The frother nozzle makes a bad screeching noise. What am I doing wrong?
I don't think there is a lot you can be doing wrong to cause that apart from maybe something not too well cleaned and creating a restriction for the steam.
2/6/2015 10:01:37 PM • Krups XP Coffee... • Answered on Feb 06, 2015
How do I disassemble Krups dolce gusto KP5000 machine?
You will need an instruction manual, if you leave your email address I will send it as a PDF file.
12/8/2014 6:21:59 PM • Krups XP Coffee... • Answered on Dec 08, 2014
Krups XP2010 Espresso Machine & Coffee Maker Logo
21 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
XP Krups
  • XP Krups
Most Popular Question
looking instriction manual krups xp2010
  • Coffee Makers & Espresso Machines
