20 Most Recent Tilia Foodsaver V835 Vacuum Sealer Questions & Answers
I had the same problem and got this information from Foodsaver:
Turn Foodsaver unbit on and press the cabncel button. That should release the unit for cleaning.
It worked for me!
Tilia Foodsaver... | Answered on May 14, 2019
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Tilia Foodsaver... | Answered on Dec 02, 2017
Does the vacuum seem to run forever and it doesn't seal?
Clean the black foam seals
Replace them if needed. they can be purchased from Tilia
WWW.FOODSAVER.COM
Tilia Foodsaver... | Answered on Mar 07, 2017
The motor has to be running for it to produce a vacum
Tilia Foodsaver... | Answered on Oct 02, 2015
Make sure you have a clean bag in there, and make sure that the belt on it is working.
Tilia Foodsaver... | Answered on Jan 02, 2015
Just plug your unit back in and press the stop button, then it will release it automatically when you press the 2 green buttons, took a while for us to figure it out.
Tilia Foodsaver... | Answered on Nov 01, 2014
Tilia Foodsaver V835 Vacuum Sealer Logo
86 questions posted
Top Tilia Kitchen Appliances - Others Experts
elementsandt
Level 1 Expert
Sheldon Dedek
Vitally Alcher
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Tilia Kitchen Appliances - Others
Most Popular Question
foodsaver v845 not sealing
  • Kitchen Appliances - Others
