20 Most Recent
Fisher and Paykel OR24SDMBGX1 Gas Kitchen Range Questions & Answers
Remove scratches from top of stove caused by
You can purchase special ceramic abrasive cleaner but I doubt it will suffice. There are other glass polishers but I suggest phoning the Fisher and Paykel customer service line for their recommendations. Cheers
How do you install motor
Unless you have refrigeration expertise it is virtually not a job for the home handyman. Th e motor and compressor are a sealed 'all in one' unit. Sorry.
Fisher paykal cooker
There is a fault with the wiring or the element. The fault started as a short circuit but has now blown itself clear to an 'open circuit' (a break). Check the element and associated wiring. I doubt the thermistat is to blame. Cheers
My oven takes forever to heat up and only heats to 150C
Nine times out of ten if the thermistat is broken then the element will come on and stay on without regulation. Hence the oven will heat up to max. I would start by checking the resistance of the element to make sure it hasn't gone high ohms, but my best guess is that there is a bad connection on the element itself where it plugs into. The element is heating up and then the connection overheats and the connection is lost. When it cooks back the connection is made again and the cycle continues. It's as though the connection is acting like the thermistat. (at 150 degrees). Good luck. Cheers
How do i dismantle a wardrobe so i can get it up my stairs
If it is not a flat pack wardrobe then there is no easy way and it depends on what timber the robe is made out of. Your only hope is to carefully try and pries apart the joints with screw drivers, hammer and a small pinch bar whilst trying not to damage the integrity of the wood itself. Start by taking off the doors to have a good look first. It may be easier than it appears. cheers
South africa
Fisher and Paykel have a 24hour help desk. Source the number, have your model and serial number handy and they will be able to sort you out.
Replace oven element
Really need to know what type of oven it is. the element is either one of two types. It will either have a socket arrangement where the element simply plugs in or the element will be hard wired. That is to say it will have wires going from the element to the oven simmerstat. If it is a plug arrangement you will usually have to unscrew a couple of retaining screws at the back of the element where it attaches to the oven back wall to remove. If it is the latter just unscrew the wires and replace like for like on the new element. Cheers
