20 Most Recent
Electrolux EW30ES65GS 30" Slide-in Electric Range with 5 Radiant Elements, 4.2 cu. ft. Self-Cleaning... Range Questions & Answers
Hi,Im tech and I have a problem with range
The F10 F11 F12 F13 F14 Error Codes indicate that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
&^%TG
Oven door is locked
Hello Lani, thank you for your post!
Based off the information you have provided your oven door is locked and you need assistance to open it up. On your control panel you should see a cancel button, if you hold that button down it should release your door. If that does not work I would recommend disconnecting power from your range for at least ten minutes. This should help clear any error within your range or control panel. If that does not correct your issue you may need to have an electrical part replaced. I would suggest having a professional out to provide a proper diagnosis and repair. This will help you avoid any unnecessary part purchases as well as future issues. -Matt
How to fix error code 15
Hi friend, thank you for your inquiry!
Based off your post your Frigidaire range is providing you an "E15" error code. "E15" stands for a signal loss between the oven relay and EOC (Electronic Oven Control) I would perform a reset on your appliance. You can do that by disconnecting power to your range by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not correct the issue it could mean that your oven relay board or electronic oven control may need to be replaced. If that is the case I would suggest seeking assistance from a professional to avoid any unnecessary part purchases. -Matt
Error code sf
sf is sabbath feature. you need to programma per user manua
After power failure, burners say 8.8 , how do I restart the stove?
Hey friend, thank you for the post!
Based off the information you had a power failure on your Electrolux range EW30ES65GS and now your burners are reading 8.8. The best way to reset your stove is to remove power from it you can do this by unplugging your range or flipping the household circuit breaker, for ten minutes. When you restore power to your range, if it still reads 8.8, I recommend contacting an authorized technician. Hopefully this information is helpful. -Matt
How to fix electrolux self cleaning gas range?
Good Morning Friend,
I understand you want to know how to fix your Electrolux range, model# EW30ES65GS. Typically, most repairs are not do it yourself repairs, as there are no step by step instruction manuals. I suggest contacting your local authorized dealer for further assistance. They have been trained on your appliance and should be able to replace the pump with ease. Hope this is helpful.
-Best Regards-
WP
Remove and replace the control display
Good Afternoon Mr. Stevenson,
I see that you are looking for instructions on how to remove and replace the control display on your Electrolux range, model# EW30ES65GS. First, I do suggest having an authorized technician to make repairs such as these, so you're not left with any other damage to your appliance. Second, while I don't know of an actual instruction manual that will help to replace the control display panel, I have attached a link that will take you to a parts breakdown manual.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995621363.pdf
-Best Regards-
WP
