20 Most Recent Marcel Drucker Silver Talking 4 Button Watch for Men Questions & Answers
10.0.0.1 IP address is the default gateway of most wireless routers or ADSL modems. There are several IP main addresses a router can take, 10.0.0.1 is the most common one though 192.168.1.1 or 192.168.0.1 are also other options. http://10-0-0-1ip.com/
Marcel Drucker... | Answered on Dec 07, 2017
Hi beninati1,
Welcome to fixya!
There aren't any instructions available for the Marcel Drucker talking watches. Here is a contact page so you can contact them directly: http://www.marcelwatch.com/category_s/23.htm
Good luck,
Hope this helps. Thanks,
Handie Andie
Marcel Drucker... | Answered on Jun 20, 2011
yes, you can replaced it at any watchmakers of your choice but you had to be sure that he is a certified watchmaker. for that other pretend but they are not.
Marcel Drucker... | Answered on Jul 24, 2011
It sounds like it could do with a clean. Most makers recommend cleaning every 2-3 years, so perhaps yours is a little overdue.
Marcel Drucker... | Answered on Feb 16, 2011
I can only suggest that you call around your area where you live and see who replaces batteries. Try your local mall....most malls have a watch repair kiosk or call a local jeweler who sells watches.
If no place local, you can send them to an on-line repair such as the one in the following link: Good luck.
http://jjwatchrepair.com/
Marcel Drucker... | Answered on Aug 21, 2010
"G-Shock WR20BAR" could mean hundreds of different G-Shock models. If yours is an all digital G-Shock, the answer is fairly simple. When looking at the watch face, the upper left corner button is the "ADJUST" button. Press and hold the ADJUST button for a couple of seconds. You should start to see something flash on the display. Some models will have many options to select in ADJUST mode. To scroll through them, press the MODE button, which is in the lower left corner. You set the hour, minute, seconds, month, date, and year each separately. When you are done, press the ADJUST button again and you'll be back to normal time keeping.
If you want to learn more about your G-Shock, there is something called a "MODULE" inside it that is the brains of the watch. You can find that on the back of the watch, outlined in a rectangle. Usually a 4 digit number. You can download the manual for your watch using that number, if you enter it on a CASIO website:
http://support.casio.com/en/manual/manuallist.php?cid=009
Watches | Answered Yesterday
The middle crown needs to be pulled out to the first position, then rotate to adjust the date. If the hand rotate you have pulled the crown out to far
Unscrew the four small phillips head screws on the back of the watch. Gently pry the back cover off, try not to damage the seal.
Watches | Answered 2 days ago
use the little thing that looks like a screw
Watches | Answered on Oct 14, 2018
Marcel Drucker Silver Talking 4 Button Watch for Men Logo
Popular Tags
10 questions posted
Top Marcel Drucker Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Marcel Drucker Watch Expert? Answer questions, earn points and help others
View Most Popular
  • Marcel Drucker Watches
Most Popular Question
mens talking
  • Watches
