20 Most Recent Basix BX-PC102 Calculator Questions & Answers
There should be a switch that has 5/4 on it. This is the rounding switch. Place it in the Up position to round all numbers up, 5/4 to round down when the next digit is less than 5 and round up when 5 or greater, and the down position to always round down.
Basix BX-PC102... | Answered on Feb 26, 2010
needed a ink roller. I found it at Office Max.
Basix BX-PC102... | Answered on Apr 11, 2009
if you have the same one I have, the Basix BX-PC 102 12 digit printing calculator it doesn't use a ribbon. (maybe that's why there's so inexpensive) It uses an ink roll - IR 40T. I'm searching for one locally now and can't find it. It seems you have to order them online.
Basix BX-PC102... | Answered on Apr 10, 2009
Steps to Canon mx410 wireless setup Step 1: Click in the notification area on the "Network Connection" icon, select from the list your wireless network and click on the "Connect" button.
Step 2: Right-click the network, select "View Connection Properties" from the context menu and then select "Show Characters."
Step 3: Write down the information next to the Security Type, Encryption Type and Network Security Key, then click "Cancel."
Step 4: Connect one end of the data cable to a numbered port at the back of the router and then connect the other end to the printer.
Step 5: Press "Windows-Q," enter the search bar with "IJ Network Tool," then select "IJ Network Tool" from the outcomes.
Office Equipment... | Answered 7 minutes ago
Follow these methods.
Method 1: Please remove files from the Temp folder and then try to install the printer driver again and check the issue.
You can run Disk Cleanup on the Operating System drive to delete contents of the Temp folder.
Now, try installing the driver from the website.
http://www.epson.co.uk/gb/en/viewcon/corporatesite/products/mainunits/support/12648
Method 2:
You may try installing the printer drivers in a Clean boot state from manufacturer's website.
You can start Windows by using a minimal set of drivers and startup programs.This kind of startup is known as a "clean boot." A clean boot helps eliminate software conflicts.
How to troubleshoot a problem by performing a clean boot in Windows 8
http://support.microsoft.com/kb/929135
Please note:After troubleshooting, make sure to place the computer back to normal Startup Mode by following the same KB article.
Office Equipment... | Answered Yesterday
Error type : T03 (Clamp motor)
T03-502 : Clamp sensor A and B do not change within 800 ms when the clamp motor operates in the forward direction during clamp unit initialisation (clamp sensor A starts at ON).
If they let you bring your own calc then get one with memory. Use memory for info.
Basix BX-PC102 Calculator Logo
5 questions posted
Top Basix Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a Basix Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Basix Office Equipment & Supplies
Most Popular Question
must hit button now calculator rounds
  • Office Equipment & Supplies
