Hello - I understand the lights are blinking; however will the display illuminate or allow you to program a setting? If it will not allow you to do so, try resetting the unit by either unplugging it or flipping the household breaker off. Wait approximately two minutes and turn on the dryer. Select a normal cycle and if it is ineffective contact a professional to move forward accurately. The unit may possibly have a defective cord or wiring, control board or door switch.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
49 questions posted
250 Questions
7 Questions
