20 Most Recent Marvel 6SDZE-BD-R Wine Cooler Questions & Answers
E2 error code on marvel wine chiller
Download the PDF manual for your model online then follow the steps.
3/31/2019 7:19:27 AM • Marvel... • Answered on Mar 31, 2019
0answers
I have a Marvel 6BAR6013 beverage cooler. The cooler seems to just run and never turn off. When I lower the temperature the unit does turn off but never back on.
I cannot locate any parts for that unit or even that model number but it appears from your description that the temperature sensor has issues. I am not able to tell if it is a themistor, bimetal spring or capillary tube type. Which ever type it is, it needs replaced.
11/24/2021 6:34:24 PM • Marvel... • Answered on Nov 24, 2021
Marvel ice maker has started making thin ice??
perhaps the filter needs changed
11/24/2021 6:33:38 PM • Marvel... • Answered on Nov 24, 2021
My Marvel ice maker suddenly stopped making ice. I checked the grid cutter and there is a broken wire. Would that account for the problem?
Yes, the grid cutter is a heating element. The element is now broken.
3/8/2021 11:55:22 PM • Marvel... • Answered on Mar 08, 2021
Marvel 6BAR MA fridge. New compressor 2yrs ago. Now runs only when it wants to but when it does it cools fine. Lowering temp knob does not trigger cooling, just randomly kicks on at any given time.
Need to know if the compressor motor gets power, does it heat up on top? If it does, then the motor starting device or a electric connection would be defective.
If no power to the compressor and is ambient room temperature to touch, the controls are at fault, defrost timer, thermostat, connections.
Work carefully around power, shock and fire hazard.
9/16/2019 8:41:58 PM • Marvel... • Answered on Sep 16, 2019
MARVEL 24 Beverage Center Model No: 6BARM-BS-G-R does not get cold.
Please first check if the compressor is running or not, secondly check the compressor, piping for leakage of refrigerant. If there is leakage the must be some oil on the pipes just near to compressor.
5/7/2019 1:30:06 PM • Marvel... • Answered on May 07, 2019
What is wrong with a marvel refrigerator that ices up
If it is supposed to be frost free, then quite often, the drain outleft for the defrost water can be blocked, keeping the water inside the cabinet allowing it to refreeze.
4/21/2019 9:58:29 PM • Marvel... • Answered on Apr 21, 2019
0answers
Marvel 6SDZE-BD-R Wine Cooler Logo
2 questions posted
Top Marvel Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Marvel Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Marvel Refrigerators
Most Popular Question
e2 error code marvel wine chiller
  • Refrigerators
