Troubleshooting & Support
Hot Topics:
- lg power...
- frost bottom...
- lfc20760
- ice
- compressor
- parts
- model
- electrical
- bulb
- power cord
- lfc20760st lg...
- condensation
- fuse
- power
- problems
- replace fuse
- fan
- sound
- Refrigerator
- cold
- board
- blowing cold...
- LG LFC20760ST
- freezer fan
- bottom freezer...
- dripping
- fridge working...
- circuit
- freezer cold
- lg
- View All »
Problems & Solutions
Just need to replace that 15 amp fuse on the
most fuses on the board are only replaced with the board . I would use a after market fuse of the same rating . and if it blower it again...
Hi, My fuse is out
the fuse is soderedto the board and is not to be replaced as a replacement part . but that doesn't mean that you cannot replace it . it...
My lg fridge just stopped working no lights or
I have a similar manual that shows just what you are up against. How about the power cord itself? Is it ok? FRENCH DOOR REPAIR MANUAL
We frequently get a high-pitched sound-very
Tour freezer fan is building up ice. Unplug the machine for two hrs. and it will be fine.
The refrigerator portion appears to
First check this things, is the compressor and fan on the compressor running. Mostly it will run, because in most of the cases it runs....
I cleaned my refrigerator out
unplug the fridge and plug it back in after a couple of minutes. this will reset the control board located behind the fridge. if after...
Our LG LFC20760S refrigerator/freezer coldness
That MIGHT be the control board but before you order anything you should check the thermistors. The board relies on data from them...
Does the LGLFC20760ST refrigerator come with
Hi and Welcome to FixYa, I am Kelly This refrigerator does not have in-door ice feature. It also does not have a water filtration system....
all power to the refrigerator has gone, all lights
ck the main power board as i think its failed .. ( in the back under a metal cover plate . ) board has fuses on it and will cause your...
Refrigerator is getting no power compressor does
If it feels like the whole thing is dead in the water, then it is probably your fuse in the back. always include the year and the make of...
fridge acts like theres no power coming in.
dose it over het
Rrefrigerator not running
check to see if you have a ground fault circuit on the receptacle you are using the frig on. Or maybe a breaker in the breaker box might be...
fridgew/ice maker. ice tastes like sulfer.
This sound like you need a water filter change to the refrigerator.
I have condensation dripping right behind where
Possible that your door gasket is not sealing very well and therefore condensation forms in this area?
Why is water leaking from under LG model LFX28978
cracked or misaligned drain pan usually just dirty and out of alignment from being moved
See all LG LFC20760ST Stainless Steel Bottom Freezer Solutions
Unsolved Problems
how to change door gasket
I got the spare part, but I dont known how to change it.
noya@gov.bmpower is getting to fridge
noya@gov.bmpower is getting to fridge as the high end #'s on the freezer temp indicators are lit- ie - it jumps to 6...
I need to replace the door gasket holder (left
I need to replace the door gasket holder (left side) - this is the long white plastic piece that holds the vertical...
Hi, I have an LG bottom freezer frig and want to
Hi, I have an LG bottom freezer frig and want to clean the coils. Do I need a special brush, are the coils on the...
My fridge was off when
My fridge was off when i woke up this morning. We've checked our outlets and they're fine. Could it be a fuse?
The fridge is off but
The fridge is off but the freezer is on. The freezer number light stays on 6 and 7 and will not change when we try to...
The Refri side don't working, just working the
The Refri side don't working, just working the freezer side. Also, the lifht on the refri side is turnig off (bulb is...
Hi, my refrigerator side don't
Hi, my refrigerator side don't cool at all, only the freezer is working. Also the light in the refri side is turning off...
freezer works but the refrigator
freezer works but the refrigator does not get cold,you have to un plug the refridgator and plug it back in order for it...
Refrigerator stopped working. Freezer is
Refrigerator stopped working. Freezer is still working.
See all LG LFC20760ST Stainless Steel Bottom Freezer Problems
Manuals & Guides
TopDo you have a manual for LG LFC20760ST Stainless Steel Bottom Freezer French Door Refrigerator? - Upload it to FixYa!
Upload a manual for LG LFC20760ST Stainless Steel Bottom Freezer French Door Refrigerator
Specifications
TopProduct MPN
Full Product Name:LG LFC20760ST Stainless Steel Bottom Freezer French Door Refrigerator
MPN:LFC20760ST
Key Features
Refrigerator Type :Bottom Freezer
Refrigerator Type :French Door
What's your problem?
Fix-O-Meter
2,815
2,815 people have viewed this product
- 45 people asked about this product.
- 14 people found solutions for this product.
- 1 person has added this product.
Pins on the...
How to fix your...
Ice Maker...
