20 Most Recent Amcor WV50 Compact Wine Cooler Questions & Answers
2answers
My 3 year old amcor wv50 needs a new control
Hi nancy641,
I am sad to say but Amcor is no longer in business. Please read the following, and note the first line after the heading. -> LINK
You will also notice the Amcor official website is down. I would suggest calling around your area for Appliance Spares stores, they may have an old board lying around somewhere.
Alternatively, I'd suggest you take the PC Board to an Circuit board repair depot/shop. They can usually locate a dry joint, or blown component and replace it for you for relatively cheap.
Don't bother looking on online spare stores, as these no longer manufactured parts would most likely be sold out.
I wish you all the best with your Wine Cooler.
Kind Regards :-)
JEDEMEYER1
* If this solution as at all helped you, please accept it.
8/4/2011 11:14:31 AM • Amcor WV50... • Answered on Aug 04, 2011
I am looking for a manual for an amcor fridge meteor 500 MF
Try this link http://kitchen.manualsonline.com/manuals/mfg/amcor_inc/wv_50_1.html I'm not finding a clean reference. Please check the make and model numbers and then try to Google them yourself with the key words "user manual" cheers
7/17/2016 3:33:00 PM • Amcor... • Answered on Jul 17, 2016
A glass shelf in my fridge broke- how do I get a new one?
try going to this website - repairclinic.com
7/27/2015 5:46:04 PM • Amcor... • Answered on Jul 27, 2015
0answers
0answers
I had a power failure
If the food defrosted then no its not safe to re-freeze, but if the door was kept close then it should of maintained a frozen state.
3/2/2011 1:33:36 PM • Amcor... • Answered on Mar 02, 2011
Need service tech seems like
Do a Google search for "refrigerator repair" in your city and state...
heatman101
9/18/2010 4:06:40 AM • Amcor... • Answered on Sep 18, 2010
0answers
Hi, i moved an amcor
Be the first to answer 9/16/2010 12:12:02 PM • Amcor... • Posted on Sep 16, 2010Be the first to answer
0answers
WV150 doesnt cooling
Be the first to answer 12/3/2009 4:23:16 AM • Amcor... • Posted on Dec 03, 2009Be the first to answer
2answers
When Should You Consider Copper for Water Storage?
Copper has anantibacterial effect. Studies recommend storing water in copper containers for several hours before consumption to maximize this benefit. Some research suggests 48 hours. perhaps explore dedicatedcopper water bottlesfrom reputable sources for optimal water storage. This refers to water, not juices.
4/15/2024 9:35:55 AM • Refrigerators • Answered 22 hours ago
I have a 1984 Norcold 8310 series RV refrigerator that isn't working. How can I troubleshoot it?
Question edited for clarity. Help and videos in the link. However it is 40 years old and has probably seen better days. There isn't much you can do if it needs refrigerant gas as you need a certified engineer. https://www.google.com/search?q=1984+Norcold+8310+series+RV+refrigerator+that+isn%27t+working ..
4/13/2024 5:04:34 AM • Refrigerators • Answered 3 days ago
3answers
Is it normal that the compressor is too hot too touch?
yes it is
4/9/2024 3:41:40 AM • Refrigerators • Answered on Apr 09, 2024
Question mark flashing next to temperature numbers
All questions need 'make model (what it is) first 3 words please. https://www.google.com/search?q=Refrigerator+Question+mark+flashing+next+to+temperature+numbers ..
4/6/2024 11:28:44 PM • Refrigerators • Answered on Apr 06, 2024
2answers
Freezer is over freezing resulting in the the fridge not cooling. model of fridge RS22DCMS water dispensing upright fridge freezer
Sometimes the timer jmalfunctions and the refrigerator will not go in to a defrost mode. Try unplugging it and defrost the refrig and plug it in again.
4/5/2024 9:37:23 AM • Refrigerators • Answered on Apr 05, 2024
2answers
Uline beverage fridge loose door handle.
Hi
You are right. The only way to repair this is by replacing the complete door assembly. If under a year it should be covered.
3/25/2024 5:55:15 PM • Refrigerators • Answered on Mar 25, 2024
Where is the defrost timer located in hisense upside down fridge freezer on model NO# HR6BMFF520S
The defrost timer in a Hisense upside-down fridge freezer, model number HR6BMFF520S, is typically located within the control panel or the refrigerator compartment. Here are the general steps to locate it:
  1. Check the Control Panel: Start by inspecting the control panel of the refrigerator. Look for any knobs, buttons, or switches that control the defrost cycle. The defrost timer may be integrated into this panel.
  2. Inside the Refrigerator Compartment: If you don't find the defrost timer in the control panel, check inside the refrigerator compartment. It might be located near the temperature control settings or the light fixture. You may need to remove any covers or panels to access it.
  3. Consult the User Manual: If you're having trouble locating the defrost timer, refer to the user manual that came with your fridge freezer. It often contains detailed diagrams and information about the location of various components, including the defrost timer.
  4. Contact Hisense Customer Support: If you're still unable to locate the defrost timer, consider reaching out to Hisense customer support for assistance. They can provide specific guidance based on your refrigerator model and help you locate the timer.
Once you've located the defrost timer, you can follow the manufacturer's instructions for troubleshooting or replacing it if necessary.
3/21/2024 2:20:27 PM • Refrigerators • Answered on Mar 21, 2024
Amcor WV50 Compact Wine Cooler Logo
1 questions posted
Popular Products
Top Amcor Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you an Amcor Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amcor Refrigerators
  • Amcor Refrigerators
Most Popular Question
3 year old amcor wv50 needs new control
  • Refrigerators
