20 Most Recent
Ezip The E-450 Scooter Questions & Answers
Brake stuck on
remove first the tire then if will unlock the bake...but clean the brake pad check if still have a thickness in the brake pad.....u
Tightening brakes
Most brake levers have an adjustment barrel. You loosen the lock nut, unscrew the cable adjusting barrel a few turns to take up cable slack & adjust the brake lever freeplay then tighten the lock nut.
2 wires broke off in the power switch on the
Have a look at the user manual wiring diagram on the Currie web site. The power switch is in the battery + line. if the wires broke off then you should be able to see from where if you look closely at the switch connectors.
Tomahawk E Series Exercise bike loud peddling sound
Standard WD40 is just a 'quick fix' as it isn't an actual oil unless the can is clearly labelled as "Bike All Condition Lubricant". It'll be best to buy a proper light oil like 3in1, 151 Super oil or an actual chain lube.
This 'clickey' noise. Is it random and happening every so often or is it a constant, regular click that changes with the speed your pedalling at? Check for slack in the chain. as you wiggle the chain up and down there should only be about a centimetre of movement in the chain. If it's too slack or too tight it can make strange noises. Check the axle bolts and nuts to make sure they're not loose. Check the wheel is mounted straight. If it's turned left or right the chain will 'skip' as it's slightly missing the cog teeth on the wheel. Use the frame at the rear end of the wheel as reference and measure how far the side of the wheel is from the frame on both sides. It should be about the same both sides.
9/22/2023 12:16:04 PM •
Cycling
Answered
on Sep 22, 2023
New Balance 6100 Recumbent Bike making a clanking noise when pedaling
I have done a tremendous amount of research on this problem. New Balance (Fitness Quest) is out of business as of late 2012 and no parts are available. The main bearing or crank bearing set is 100% compatible with Proform part number 295560. Since New Balance put their name on this product, they have stated they will reimburse customers for the repairs.
4/5/2023 11:21:09 AM •
Cycling
Answered
on Apr 05, 2023
