portable sunpentown air conditioner/heater blows non heated or cooled air. after cleaning coils, red...
(More)
portable sunpentown air conditioner/heater blows non heated or cooled air. after cleaning coils, red power light beeps and alarms.
I have an SPT WA-1220E Portable A/C unit that is leaking when running. It will auto shut off when it...
(More)
I have an SPT WA-1220E Portable A/C unit that is leaking when running. It will auto shut off when it detects it is full, but Im wondering if it is filling before it shuts off...? It has a rubber plugged release tube where I drain the water, it drains fine and is definitely not plugged up. I also tip it backwards to get every bit of water that will come out of the drain. I then replug the drain tube. I turn it on, it runs perfectly, cools the room, then an hour or two (sometimes more...) goes by and when I check the area the right side (when facing back of unit) is starting to leak water from the bottom of the unit. Near as I can tell it seems to be coming down from the back right wheel area. Im tired of towel drying and using a hair dryer to dry the carpet. This thing runs fine, it cools the bedroom well. I purchased it used and have no manual and know nothing about A/C units. But, Im on the verge of taking the outside covers off, to see if it has a loose hose or a bad water detection sensor, if there is such a thing...? Would appreciate any assistance !
I had this fellow ask why he couldn't find any thing about id model number for buying a replacement out door ac unit. The answer I game him is part...
written by farfield
Typically if you want a circuit completed when energized you use C (Common) and NO
(normally open). This means that the contact will close when...
written by farfield
A low charge diagnosis for instance can be miss read if the evaporator
is iced up or has any ice in or on it. A sticking thermostat, relay,
or...
written by farfield
What I have always been told is if your 24 volt side burns out check
the high volt side if the hi volt side burns out check the low volt
side. A...
written by farfield
If your wondering how to check out your refrigeration
compressor;
Modern Compressors have two operations that have to work
together just to run....
written by farfield
Examine the air filter at the beginning of each cooling and heating season and at the beginning of each day light savings time change. Write the date...
written by farfield
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps.
Steps:
1. Add attic insulation....
by wikihow
If your tap water is cool, you can air condition a room with it at minimal cost.
Steps:
1. Obtain a radiator from a small car such as a Honda Civic,...
by wikihow
Steps:
1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing...
by wikihow
Service and Repair, System Maintenance, Advantage Mem... Read More
Service and Repair, System Maintenance, Advantage Member Plans, Replacement & Installation, Guarantees, Air Cleaning and Purification, Duct Sealing, Duct Cleaning, Indoor Air Quality, Heating, Air Conditioning and Indoor Air Quality Products, and Commercial Services for your business.
