20 Most Recent Tag Heuer AquaracerWAF1110.BA0800 watch Questions & Answers
Just replaced a women's Aquaracer battery. It's a 364. Get the SR (silver oxide type) as it will last longer.
Tag Heuer... | Answered on Aug 05, 2014
it have the battery to be reolaced.. bring it to watch service center.
Tag Heuer... | Answered on Jul 24, 2011
Links need to be ordered from TAG.They cost about £30.00 per link best contact www.rolexrepairs.co.uk if you send them the watch they will supply and fit with a free estimate first.
Regards
Tag Heuer... | Answered on Aug 19, 2010
I think it depends upo which model you have but the web site does not discuss this.
Generally, if it says "automatic" then it is spring driven (does it stop if you don't wear if for a few days?).
If it keeps going, when not worn then i is a battery driven type.
You can see the range of models on their web site http://www.tagheuer.com/the-collection/aquaracer/man/leonardo-dicaprio-ltd-edition/index.lbl?w=WAJ2116.FT6022. and you may be able identify yours from their list.
Tag Heuer... | Answered on May 12, 2010
Any jewelry store that sells watches, or even those little watch kiosks at mall should be able to help you with that.
Tag Heuer... | Answered on Apr 02, 2010
The knob is a screw-cap seal. When closed (screwed in) it closes the chamber to prevent water from entering the watch.
You will need to unscrew it. It should snap out. In this position, you can wind the watch. Pull the knob out one click, and you can adjust the date. Pull the knob another one more click, and you can adjust the time.
Push the knob back in. In order to seal the watch back up, you will need to push the knob in while turning the knob. You will know you did it correctly when the knob will not turn any further.
Good luck.
Tag Heuer... | Answered on Mar 25, 2010
It depends. Maybe your skin is very sensible. May be the material used is't good for you. But mostly the main reason is: crown (you say knob) is too large for the wearer or have too sharp edges. Visit your nearest watch repair shop and explain what the problem is. Watchmaker will find other crown (different in shape and size, but no lesser quality) and will fit to your watch for your comfort. Rate me, plz.
Tag Heuer... | Answered on Feb 19, 2010
Yes it is correct as your watch has a counterclockwise crown forward setting direction. This is due to the specificaly layered lever and setting gear construction, so, nothing wrong with your watch.
Do not forget to rate, please.
Tag Heuer... | Answered on Jan 27, 2009
There are several links that have a pin that can be removed. Removing two adjacent links and replacing the pin without the middle link is that way to do it. I could go on and on, but this site shows you how...
http://www.webjeweller.com/jewellery/removelinks.shtml
Ken
Tag Heuer... | Answered on Aug 15, 2008
Tag Heuer AquaracerWAF1110.BA0800 watch Logo
14 questions posted
Top Tag Heuer Watches Experts
Arturs Kalnins
Arturs Kalnins
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
View Most Popular
2000 Tag Heuer
  • 2000 Tag Heuer
Most Popular Question
tag heuer watch
  • Watches
