20 Most Recent IBM Thinkcentre M50 8185-E3u Pc - XP Pro - P4 2.8 GHz - 40 GB - 512 MB - CD-ROM Questions & Answers
Step 1:
Are you upgrading or installing from a disk ?
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
IBM Thinkcentre... | Answered on Feb 06, 2013
Have you tried using an external monitor to make sure the video is working on the new motherboard?
IBM Computers &... | Answered on May 08, 2019
I am not an expert in such things but I think if you use a widely available adaptor that will power the old hard drive and provide usb connectivity your Windows 7 should be able to read and allow you to move files, as long as the old drive and the WIN 7 are both 32 BIT (or 64)...
IBM Computers &... | Answered on Apr 27, 2019
hi, try using a vlc player to play, if you dont have download it from here:
http://vlc-media-player.en.softonic.com/download
IBM Computers &... | Answered on Apr 25, 2019
Download NSF to PST File Converter tool to convert NSF data into PST file format. This NSF to PST converter Software nicely convert NSF file to PST, EML and MSG format with whole versions of Lotus Notes NSF and Outlook file.
More Info :- NSF to PST File Converter
Bad memory stick, possibly. Or maybe bad motherboard. try different memory, and try swapping to different slots.
IBM Computers &... | Answered on Mar 18, 2019
Win10 should auto-detect it; so it should need a driver from it manufacture.
Assuming the monitor is properly functioning, and if you are still having problems:
1) Use the most up-to-date connection such as HDMI, DVI, or Display Port
2) Then with the monitor connected, force a Windows update.
3) Make sure the display adapter's resolution matches one of the monitor's supported resolutions.
IBM Computers &... | Answered on Dec 19, 2018
It is called a 'reformat' on a computer. See the details in the link
ibm thinkpad t43 reformat Google Search
IBM Computers &... | Answered on Nov 26, 2018
Try the drive on other usb ports first.
Listen for the windows "Beeps" when you plug it in or take it out. If the beeps are heard then you need to go into Disk Management and assign drive letters to the partitions
IBM Computers &... | Answered on Sep 24, 2018
Epson driver might work. Could try a DOS text print.
http://www.fixya.com/support/t976965-problem_printing_ibm_4610_tf6
Copy of FIXYA page shown:
Question about IBM 4610 TG4 Thermal Label Printer
Problem printing with IBM 4610 TF6
I have this printer and i can't print with it on windows XP, i connected the printer with RS323 cable and it doen't communicate with the computer, i tried the IBM driver and no good.
can u plz help me.
roy
Posted by ras81 on Aug 28, 2008
ras81 Aug 28, 2008
hi
the cable is ok, because i already replaced it, the cable is new....
i think it's some kind of driver issue, but the driver on IBM site just won't work.
Furqan Sep 05, 2018
Hi
I also want drivers for my printer but there are none. How could i find them?
Bernie Role
Bernie Role
Expert
Download and use this driver instead, EPSON TM-88II Printer Driver, 4.00.
Good luck.
Posted on Aug 28, 2008
Helpful 0
Not Helpful
Comment
Flag
monk3ybidzness
monk3ybidzness
IBM Master
Use generic text driver - go for LPT (default port) then change the installed printer properties later.
get the serial settings of the printer first (bauds etc).
Helpful 0
Not Helpful
2 Comments
Flag
monk3ybidzness
monk3ybidzness Aug 28, 2008
add:
make sure that it is a 24/9 pin NULL-MODEM serial cable
monk3ybidzness
Just use the Generic Text Driver type autoexec.bat>lpt1:
or
C:\>type filename.txt>LPT1:
If that works consistently, the problem is probably in Windows.
Be sure Windows is set-up correctly with the correct printer driver and something else (another printer, FAX, etc.) is not assigned LPT1: Be sure the 710 is set as the default Windows printer. Try it on another desktop computer. If that works, try another printer on the suspect computer. I have seen cases where a baby AT motherboard was upgraded, but the printer cable/header assembly from the old motherboard was used and caused problems, but that is very rare. Also, the cable connecting to the motherboard could be backwards or loose.
IBM Computers &... | Answered on Sep 06, 2018
IBM Thinkcentre M50 8185-E3u Pc - XP Pro - P4 2.8 GHz - 40 GB - 512 MB - CD-ROM Logo
1 questions posted
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • IBM Computers & Internet
Most Popular Question
ibm m 50 not install windows 8
  • Computers & Internet
