20 Most Recent Sharp XE-A202 Cash Register Questions & Answers
Log in clerk
Sharp XE-A202... | Answered on Aug 28, 2016
Hi. Common problem. Sharp had a manufacturing defect in the drawer. The two white wires were not dressed behind the tray. The tray comes back and cuts through the wires over time. This causes the drawer drive circuit to short out. Sharp may still be covering this problem so check with a local dealer (The F means finalised or sale finished, so the drawer should open at that time). Great model but shame they got this wrong. Usually not too bad to fix but needs a tech.
Sharp XE-A202... | Answered on Nov 07, 2015
If the F is at the left then it just means finalised or sale finished. This means the sale was completed normally. The drawer is probably not opening because that model had a factory fault where the back of the tray cut through the drawer wiring. If you take the tray out and check the two white wires inside, you may find one of them has a small cut in it. If so, it usually blows the drawer circuit and it will need a technician to fix it. There was a recall on them for this problem so check with a dealer as they may still do it for free. Great machine but this factory fault was a pain.
Sharp XE-A202... | Answered on Oct 30, 2015
Use the alphabet layout on the keyboard to enter the letters. There are special line number codes in your manual to enter each line. If the alpha layout is mising from your keyboard, your manual will have a diagram. if you need a manual, one of the users has it here:
https://the-checkout-tech.com/manuals/cashregisters/Sharp13.php
Sharp XE-A202... | Answered on Sep 27, 2015
It sounds like you are seeing the time display. Turn the key to REG mode and try pressing CL (clear). If it doesn't beep, get the keyboard checked by a technician
Sharp XE-A202... | Answered on May 16, 2015
Do an initial reset
Sharp XE-A202... | Answered on May 14, 2014
Make sure the printer cable is properly inserted
Sharp XE-A202... | Answered on Apr 12, 2014
What do you want to program. Please specify
Sharp XE-A202... | Answered on Mar 18, 2014
insert you OW key and set it on half-past position and back to reg
Sharp XE-A202... | Answered on Mar 11, 2014
There is a lever under the cash drawer . push it to the left
Sharp XE-A202... | Answered on Oct 11, 2013
press rcpt key on time mode
check you keyboard
You are not logged in. press 1 then the # key then you will be fine
Its not the display, its the keyboard. pluck of the sub total key then press cl button..good luck
Sharp XE-A202 Cash Register Logo
27 questions posted
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Jim Keysor
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Retail Supplies
Most Popular Question
sharp xe a202 nothing working after
  • Retail Supplies
