20 Most Recent
Mad Catz Officially Licensed NFL Dallas Cowboys PS2 Controller by Madcatz Questions & Answers
Madcatz
You may need a different driver file. If the driver you are trying to use is 32 bit only, then you can not use it for 64 bit windows.
I have a mad catz steering wheel and pedals for a pc. Can it be hooked up to a ps2?
No. But...
search for "peripheral adapters", because it used to be you couldn't use a keyboard and mouse with console games but now a few companies actually make hardware that allow you to plug in USB devices to use with PS/3-Xbox, etc. So, probably still no on PS/2 but maybe searching under ps2 hacks might find some ingenious hardware wizards?
Need to sync blue tooth
You need to go to the Bluetooth settings on the PS3 and find the Pair Device option. Then you need to set the device you want to sync to broadcast its details - without knowing what device you want to sync, I can't help you there, and then the PS3 should then see your new dvice and sync once connected.
My mic on my ps3
A common issue if that the PS3 is not set to pick up audio from your mic. Go to Settings, look for the Mic settings and check that the mic is indeed the input source selected. Also check that the battery is charged up enough, it is corectly paired - as per the instructions - or it is properly plugged in.
