20 Most Recent Sony Bravia EX440 42-inch KDL42EX440 1080p LCD HDTV Questions & Answers
try a diferent cable like vga ,dvi, hdmi 24848054-qc1lpawb5g1rdd4grryp23j1-1-0.jpg 24848054-qc1lpawb5g1rdd4grryp23j1-1-2.jpg
Sony Bravia... | Answered on Nov 25, 2014
The identifiers on the Sony transistors are proprietary part numbers so only Sony can identify equivalent parts, if any.
Sony Bravia... | Answered on Apr 28, 2014
You need a special cable.
Sony Bravia... | Answered on Dec 21, 2012
its probly the game disc mate. its had its day. u can send them to shops that fix disc 4 u, 4 a cetain price. if it still dont work then only option is to by new fifa games.
Sony Video Game... | Answered on Jun 13, 2019
First you will need a pin out of the adapter.
Tools you will need are.
1: Solder with rosin core thin solder would be best 2: Soldering iron lower watts the better 3: Flux to clean the surface you want to solder to 4: Sponge to clean the tip of solder iron If you don't have any of thous supply's it would be cheaper to buy a new cord. Also if you don't have vary much experience soldering i would also recommend getting a new cord for the fact you can cause more damage than good.
To get the solder iron ready you need to heat it up. Once it is hot enough to melt the solder apply the solder to the tip and let is set there until you want to solder. You have to clean the tip off with a wet sponge but not soaked in water just enough to get it wet. Every time you go to solder Clean the tip off and apply fresh solder to it not a lot just enough to cover the tip when you want to solder. When you go to store the iron apply a small blob of solder to the tip to keep it from oxidizing.
Strip the wire shielding off a bit longer than the size of the contact you want to solder. Twist the wire and put flux on the surface you want to solder and tin them.
Tinning the wire is just applying a small amount of solder to the wire as to hold the strands together and make it easier to transfer the heat and solder to the contacts. Now mach the pin-out to the weirs to the contacts and put flux on the contact you want to solder to. Clean the surface by applying flux to it.The surface will be oxidized and will not let you transfer heat or solder to the surface. The key to soldering is to use the right amount of heat , solder and time you hold the iron to what your soldering to. You want to make sure you touch the wire and the contact you are soldering to as to transfer the heat to both items at the same time to make the solder flow. Put the solder wire to the tip of iron that is touching the wire and contact and not on top of the iron tip. Any time you apply heat to solder joints you want to use flux to keep them clean and free of oxidized material. After you solder check the solder joints for cracks, uneven and dull surface. You want the solder to look as shiny as possible and smooth. If it looks like it has waves or holes and cracks it means you have a cold solder joint and must reheat and apply flux with a small amount of solder to fix it .Here is a link to help you out this is not my site and full credit goes to the owner of site. How To Solder Soldering Tutorial Also put a link to a new cord if you decide you want to get a new one. Here is a link that may or may not help with the pin-out. Also not mine it should credit the poster on the forum as he did all the work i just found it PSP Go Cradle mini USB Tutorial with Partial Pinout PSP Go Acidmods com
Sony Video Game... | Answered on May 28, 2019
may be you need cdkeys for the game, or your consoles do not work, you need find what prolem actually is, if need cd keys you can have a view on https://www.m8x.com, if your console do not work, you should repair it, if you need FIFA Coins, FUT Coins or FIFA 19 Coins, you can have a view on https://www.fifacoin.com
Sony Video Game... | Answered on Feb 21, 2019
Hello, in order to download some free games you have to visit the PlayStation store and then search for the game you want to download. Not all games are available for free, there is a selection of games you can download for free, you can only download three.
Sony Video Game... | Answered on Dec 26, 2018
Hello my friend,if you like first person games try call of duty modern warfare 2,if you like strategy games try warhammer dawn of war 2 or command and conquer 3.If you like role playing games try lineage or world of warcraft.Personally i love call of duty
Sony Video Game... | Answered on Nov 26, 2018
Idiots, Idiots everyewhere
Sony Video Game... | Answered on Oct 03, 2018
Online, google the game and console details and add cheats.Generally a list of sites will give cheats for the game selected.Follow the commands
Sony Video Game... | Answered on Jul 30, 2018
never believe what some one says simply because you have an on board fault reporting system that has codes for the faults
Have the codes read and fix the reported faulty items
Sony Video Game... | Answered on Feb 06, 2018
Sony Bravia EX440 42-inch KDL42EX440 1080p LCD HDTV Logo
4 questions posted
Top Sony Video Game Consoles & Games Experts
shevantha perera
Damen Wong
Damen Wong
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Video Game Consoles & Games
Most Popular Question
sony kdl42ex440 q6502 q6503 part number
  • Video Game Consoles & Games
