20 Most Recent
Swingline Optima PowerEase Stapler, 25 Sheet Capacity, Black Questions & Answers
How to take apart Swingline SpeedPro 45 stapler? Model S7042141
To disassemble a Swingline SpeedPro 45 stapler (Model S7042141), follow these steps:
- Open the stapler and remove any staples that may be inside.
- Locate the two small screws on the bottom of the stapler, near the front.
- Use a Phillips head screwdriver to remove the screws. Be sure to keep them in a safe place.
- Gently pry apart the two halves of the stapler. You may need to use a flathead screwdriver or other tool to help separate the pieces.
- Once the stapler is open, you can access the internal components, including the spring, magazine, and stapling mechanism.
Note: It is important to exercise caution when disassembling any tool or device, as parts may be under tension or spring-loaded. If you are unsure how to proceed, consult the manufacturer's instructions or seek the assistance of a professional.
