20 Most Recent Acer Aspire E1-571-6492 15.6" Notebook PC - Intel Co... [NX.M09AA.005] Questions & Answers
hi there.
this is all i could find.
Why my TouchPad is not working in laptop Acer? Enable/disable your touchpad - Many systems allow you to turn the touchpad On or Off by pressing the FN and F7 keys at the same time. ... Reinstall touchpad drivers - Missing or incorrect drivers may cause your touchpad to not work properly. Check in device manager to make sure your touchpad is reporting properly.27 Oct 2014
Touchpad troubleshooting - Acer Community - 307854
community.acer.com/t5/Knowledge-Base/Touchpad-troubleshooting/ta-p/307854 Search for: Why my TouchPad is not working in laptop Acer?
or go to this link and read up some more if you need to.
Acer Aspire Notebook PC Touchpad won scroll Google Search
Acer Aspire... | Answered on Nov 27, 2017
its the hardware problem.if there laptop have the nvidia or ati graphics then resold the graphic controller with heat gun.
Acer Computers &... | Answered 11 hours ago
If the computer does not have a built in "CAPS" indicator you have two choices.
1: Install software that will show you the CAPS / NUMLOCK status.
2: Use a different keyboard (USB) that includes the status indicators.
Acer Computers &... | Answered on Jul 11, 2019
You will need a Windows 10 boot disk if you don't have one.
Installing Windows 10 using the media creation tool - create media then
boot with it.
http://windows.microsoft.com/en-us/windows-10/media-creation-tool-install
How to Create a Bootable USB Flash Drive to Install Windows 10
http://www.tenforums.com/tutorials/2376-usb-flash-drive-create-install-windows-10-a.html
OR use this method :
How to Create a USB Recovery Drive in Windows 10
http://www.tenforums.com/tutorials/4200-recovery-drive-create-windows-10-a.html
If your system came with Windows 10 the System Maker can supply the disk for a small cost since you already own Windows.
Boot with a Installation or Repair disc or USB drive - issue these from the Command
Prompt and hit ENTER after each.
C:
bootrec /fixmbr
bootrec /fixboot
bootrec /scanos
bootrec /rebuildbcd
After the above you may need to run Automatic Repair (even 2 or 3 times) - Option 5
here and run StartUp Repair to see if it helps.
How to Boot to Advanced Startup Options in Windows 10
http://www.tenforums.com/tutorials/2294-advanced-startup-options-boot-windows-10-a.html
Using EasyBCD often works when other methods do not. <-- if Bootrec did not help use this.
Translate the Windows 7 methods to Windows 8/8.1/10..
Recovering the Vista or Windows 7 or 8 Bootloader from the DVD
http://neosmart.net/wiki/display/EBCD/Recovering+the+Vista+Bootloader+from+the+DVD
Recovering the Vista Bootloader with EasyBCD (Windows 7 & 8)
http://neosmart.net/wiki/display/EBCD/Recovering+the+Vista+Bootloader+with+EasyBCD
Repairing the Windows Vista Bootloader (Windows 7 & 8)
http://neosmart.net/wiki/display/EBCD/Repairing+the+Windows+Vista+Bootloader
If all else fails you can try a Clean Installation.
If you do a Clean Install then it would be activated with the Digital Entitlement.
Start fresh with a clean installation of Windows 10
https://www.microsoft.com/en-us/software-download/windows10startfresh
Clean Install Windows 10
http://answers.microsoft.com/en-us/windows/wiki/windows_10-windows_install/clean-install-windows-10/1c426bdf-79b1-4d42-be93-17378d93e587
Acer Computers &... | Answered on Jul 10, 2019
Try removing the battery and then holding down the power button for a few minutes to discharge the cache. Reinstall the battery, and without starting the phone, plug it in to charge. If this doesn't work you will have to do a hard reset.
Acer Computers &... | Answered on Jul 01, 2019
Many password locks can be removed.The hard drive IS NOT one of them.Pretty much ,your only recourse is to buy a new hard drive and reinstall everything.
Acer Computers &... | Answered on Jun 30, 2019
ever thing to look on acer.com?
here it is 1st goggle hit BTW
https://community.acer.com/en/discussion/481946/recovery-error-code-0xc0000034
HDD boot files dead , corrupted or missing.
we test the HDD first, do the smart tests if those fail the HDD is bad and there is no recovery on HDD that is dead.
OK, learn to do tests, and in the right order or long wasted labor.
others do the hope this works thing.
skipping step one test HDD
https://www.laptopmag.com/articles/fix-0xc0000034-error-windows-10
bad hdd have corrupted OS, and corrupted everything. and if true, is DOOMED.
new HDD if bad and new OS fresh installed. if HDD is bad.
fixing this is based on pure logic even computer logic.
1: back up you data first, ( ask how ? a is x10 more difficult task on a dead PC, but do ask and is whole other long post. or lean to google, "how to backup data on dead PC"
2: then run the full Smart tests in the HDD>
if this fails your HDD is bad. a FACT.
I use my Linux demo disk to test the HDD, ask how.
buy a new hdd , put it in.
3: we then get unstated windows recovery media.
and do a fresh windows install
there are the steps, any shop or tech does.
besides the BCD repair steps seen in first link.
Acer Computers &... | Answered on Jun 27, 2019
Larry Ng is a computer and automotive expert who has warned you about upgrading the BIOS.
Information at the Acer web site is available, but requires your enter information to get the correct BIOS. You might consider paying a competent technician to do it for you to lessen the risk.
https://www.acer.com/ac/en/US/content/drivers
Acer Computers &... | Answered on Jun 26, 2019
hi,
Some users experienced similar problems when SP2 was released, so this could be the problem. If the user sees a stop error code of 0x0000007e, this first issue is likely the reason why the computer does not boot properly.
The second issue will only occur on systems with certain acer motherboards. This error manifests itself with an error code of STOP: 0x000000A5. It is unknown how to fix this problem other than by installing a USB storage device, or even possibly removing a USB mouse and replacing it with a PS/2 port compatible version.
If that is not enough, Microsoft MVP Jesper Johansson reports that there seems to be a third, less common problem with SP3 computers, this time on Intel. Some may receive a 0x00000024 stop error, which he believes may be due to an issue with either the NTFS file system being corrupted, or a faulty video driver.
go to microsoft .com under solutions page and type in the information code error they have been working on a dowload patch to correct this . go there http://support.microsoft.com.
Acer Computers &... | Answered on Jun 21, 2019
Try connecting an USB keyboard to your Acer laptop. If the external USB keyboard does not work the the laptop is faulty.
If the USB keyboard works then reseat the laptop's keyboard connector to the motherboard, it may have become loose.
Acer Computers &... | Answered on Jun 19, 2019
Acer Aspire E1-571-6492 15.6" Notebook PC - Intel Co... [NX.M09AA.005] Logo
4 questions posted
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
View Most Popular
  • Acer Computers & Internet
Most Popular Question
touchpad scroll
  • Computers & Internet
