20 Most Recent
Robot Coupe CL50 Food Processor Questions & Answers
Robot chef RC3 lid the little bit on the lid that
To valewis46 - is the lid still available as mine has been stick together that many times that it has now bitten the dust. I realise that your offer was made over a year ago but I thought I would ask - just in case. Thanks.
I have a rc3 food
Only directly from them http://www.robotcoupe.net/food-processor-parts-by-models.html
Robot coupe maintanance
That plastic piece is a sling disk or sling blade and made to sling product to the discharge chute. Believe it or not, the motor shafts wear out and could be the cause of premature failure. When you install the new sling blade, check to see how much slop/ play there is by moving this back and forth on the shaft, a small amount is ok (1/16th to 3/32nds). The other thing to look at is forcing or overfeeding the unit. You can contact them at Robot-coupeusa.com
I purchased a Robot Coupe R101 and wanted to add the Pulse button. Do I just get a R101 Plus switch and front panel? How hard is the replacement?
Thanks
To add the pulse button to your Robot Coupe R101, you will need to purchase the R101 Plus switch and front panel. The replacement is relatively simple and can be done by following these steps:
- Turn off and unplug the Robot Coupe R101.
- Remove the screws that hold the top cover in place and lift off the cover.
- Locate the control panel on the front of the machine and remove the screws that hold it in place.
- Carefully remove the control panel and disconnect the wires from the old switch.
- Install the new R101 Plus switch onto the control panel and connect the wires.
- Replace the control panel onto the front of the machine and secure it in place with the screws.
- Replace the top cover and secure it in place with the screws.
Once the new switch and front panel are installed, you will have the pulse button on your Robot Coupe R101.
Robot coupe 3b wiring diagram
Wiring diagrams are in the back of the manuals after the parts lists.https://www.partstown.com/robot-coupe/blixer-3b/parts#id=mdptabmanuals..
