Most chargers will show a green light when charged
That could take an hour
You have to or I do,charge all my items every 3 months
Not uncommon to have a failed battery in less than a year
Ideally four years & fair amount of use,but some do fail
Weight: The Aquatak 10 weighs 6000 grams, ensuring stability during use.
Maximum Pressure: Unfortunately, the specific capacity of the yellow box capacitor in the input supply is not explicitly mentioned in the available manuals. However, I recommend referring to the official user manual for detailed technical information.
Motor Power: The motor power of the Aquatak 10 is 1500 W.
Maximum Flow Rate: The maximum flow rate is 350 liters per hour.
Inlet Water Temperature: The pressure washer can handle inlet water temperatures up to 40°C.
Detergent System: It features a high-pressure foam detergent system.
Pump Type: The pump is a 3-cylinder all-metal pump.
Cable Length: The power cable is 5 meters long.
Hose Length: The hose length is also 5 meters (made of PVC).
Nozzles: It comes with a fixed fan jet nozzle.
Regarding the oil leak issue you mentioned, it's essential to address it promptly. Here are some general steps:
Turn off the pressure washer and disconnect it from the power source.
Inspect for visible damage or loose parts.
If you suspect a broken bearing, consider contacting a professional technician for assistance.
For the oil leak, I recommend not attempting to fix it yourself. Contact a qualified technician to address the problem.
Please note that the Aquatak 10 is an electric pressure washer and does not require oil replacement, as it does not have an oil reservoir. If you need further assistance, consider reaching out to Bosch's customer support or a certified tech.
The constant beeping could be due to a malfunction or error in the appliance. The first step is to consult the user manual for troubleshooting steps or error codes that might help diagnose the issue. If the manual does not provide a solution, it may be necessary to contact a professional technician for repair.
No, there are never schematics available for toys. Look for some type of indication of where the wire came from. It can only reach so far and sometimes could can see where it was soldered, or a few wire strands.
Or take it to a local model shop. They usually have people they know that fix toys.
https://www.google.com/search?q=bosch+toy+chainsaw+wiring+diagram
Check kick back lever, it is a plastic flap just before bar on top of saw. This is to stop blade if saw kicks back on you. Will have to push flap forward away from you.
