20 Most Recent
Euro-Pro G1490 Continuous Iron Questions & Answers
Power Cord
Manufacturers are getting more and more clever about hiding screws which allow covers to be removed. Probably has to do with product liability.
Anyway, look for a brand or settings insignia that can be removed - like a thin aluminum plate. Screws are sometimes hidden underneath. If the cover is a gauge for a control, be very careful not to damage it when you remove it. You will want to put it back.
How do you open the back plate to access the power connection. On a shark model G1568 iron??
We have a Euro Pro GI472, which kept going off and on, and the problem seemed to be an intermittent connection in the power circuit. If we "fiddled" with the cord, the power light would go off and on. To get the back off, I removed the two screws below the rubber feet, near the identification tag. Then I had to pop the red plastic light lens off the top of the iron. The lens is held by two plastic "claws" one at the top and at the bottom of the lens. Once the lens is out, there is a small Phillips-head screw visible between two light sources. I removed the screw, and that freed the cover, and made it possible to access the wiring. Testing continuity from the wall plug to the two wires inside the iron, and flexing the cord, quickly led to a spot in the cord that was slightly kinked, and that was the location of the fault. Both wires under the insulation were broken. In fact there were small balls of melted copper near the breaks. Then it is a matter of making sure you know which wire of the power cord goes to which spot in the iron (a photo or a sketch will save mistakes when reassembling) cutting out the faulty wire, getting a suitable crimp connector and a wire nut and rewiring the iron.
I love my iron ! How I can use in Israel?
The voltage in Israel is 220 volts. Check the information plate on your iron to see if it will operate on 220 volts. If it will, then you will only need an adapter from the two round pins to a two slot receptacle that you can plug your iron into. If your iron will not use 220 volts then you will need a 220/120 volt transformer with a 1 and one half times larger wattage rating on it than watt rating on your iron. Our iron is 1200 watts. We would need a 2000 watt transformer. On Amazon they cost eighty nine dollars and weigh 29 pounds. And they ship them overseas. Best of Luck
