20 Most Recent Cerwin Vega LS-12 Speaker Questions & Answers
Fuses have different blow characteristics. Such to protect components differently. An extremely fast fuse would protect sensitive components like tweeters and slower fuse will allow transcients to pass and blow on long time fault. If you put a slow blow in place of fast blow, it won't blow as quickly, but it could allow the protected device to be damaged. In reverse, you put a fast blow in place of slow blow, it will blow at normal transcients and be a nuscience to always replace.
You can cross to a fuse of different manufacturer. The reliable manufacturers will have detailed datasheet and subsitute or similar fuse to the fuse you are looking for.
Cerwin Vega... | Answered on Oct 25, 2013
exactly the same fuse as that was installed
maker is of no matter but the rating is critical
Cerwin Vega... | Answered on Aug 17, 2018
You'll need some adapter cables. I would probably try a Y cable in each front speaker line, then connect the pair from the left channel to the "L" binding posts on the back of the Sub. Same for the right.
Not sure of the configuration of your existing surround system. Essentially, you want to "Y" the left and right channels wherever you can get a hold of them and connect each to the back of the sub.
Cerwin Vega... | Answered on Apr 23, 2017
Cerwin Vega LS-12 Speaker Logo
6 questions posted
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Joe Lamb
Joe Lamb
Steve Allison
Steve Allison
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Cerwin Vega Audio Players & Recorders
Most Popular Question
use another 4a 250v fuse cerwin vega
  • Audio Players & Recorders
