20 Most Recent
Ryobi Curve RY26500 26cc Gas Trimmer Refurbished Questions & Answers
Engine starts & runs at idle. Dies when switched to RUN & wont accelerate.
Sounds like its a fueling issue. With small tool 2 stroke engines when you pull the throttle you actually increase the amount of air the carb gets. In turn, this rush of air through the venturi of the carb draws more fuel into the cylinder. If your engine is cutting out or wont accelerate this is generally because the engine is either getting too much fuel or not enough for the fuel/air mix to burn effectively. It could also be air getting into the fueling system by means of a damaged fuel line or carb diaphragm. By all means clean the carbon from the exhaust and clean the air filter, they can only help the running of the engine. Hope this is of some help.
Ryobi bp42 backpack blower won't stay running and spit out gas
Common issues and possible solutions:
Fuel-Related Issues:
Check the Fuel Level: Ensure that the blower has enough fuel in the tank. If it's running low, refill it with fresh, properly mixed fuel as specified in the user manual. Remember to use the correct fuel-to-oil ratio to avoid engine damage.
Inspect Fuel Lines: Examine the fuel lines for any clogs, kinks, or leaks. Clean or replace them if necessary.
Clean the Carburetor: A dirty or clogged carburetor can cause starting and running problems. Remove the carburetor, clean it thoroughly, and check for any damaged components. Replace the diaphragm and gasket if needed.
Spark Plug Issues:
Check the Spark Plug: Inspect the spark plug for signs of wear, fouling, or damage. Ensure it's properly gapped and functioning. If needed, replace the spark plug
Air Filter and Intake System:
Clean the Air Filter: A clogged air filter can affect performance. Remove the air filter, clean it, and ensure proper airflow.
Inspect the Intake System: Make sure the intake manifold is secure and not loose. Tighten any screws or connections.
Heat Soak:
Sometimes, backpack blowers experience heat soak, where the engine becomes too hot to start. Allow the blower to cool down before attempting to restart it.
Compression and Ignition Coil:
Compression Test: Check the engine's compression using a compression tester. Low compression may indicate internal engine issues
Test the Ignition Coil: Ensure the ignition coil is functioning correctly. A faulty coil can lead to starting problems.
Installing the fuel line on ryobi 410r tiller
To install the fuel line on a Ryobi 410r tiller, follow these steps:
- Prepare the tools and materials: You will need a replacement fuel line compatible with your Ryobi 410r tiller, needle-nose pliers, and a small container or towel to catch any fuel spills.
- Remove the old fuel line: If there is an existing fuel line, carefully disconnect it from the fuel tank and carburetor. Use needle-nose pliers to loosen any clamps or connectors securing the fuel line in place. Drain any remaining fuel from the old fuel line into a container.
- Cut a new fuel line: Measure and cut a new fuel line to the appropriate length, ensuring it matches the size and diameter of the original fuel line. It's a good idea to bring the old fuel line to a hardware store to ensure you get the correct replacement.
- Attach the fuel line to the fuel tank: Insert one end of the new fuel line into the fuel tank's opening. Push the fuel line in until it reaches the bottom of the tank. Make sure it is securely seated.
- Connect the fuel line to the carburetor: Locate the fuel inlet port on the carburetor. Insert the other end of the fuel line into the port, ensuring it fits snugly. If there are clamps or connectors, secure them to hold the fuel line in place.
- Check for leaks: Double-check that all connections are tight and secure. Look for any signs of fuel leakage around the fuel line connections. If you notice any leaks, recheck the connections and tighten them if necessary.
- Test the fuel line: Add fuel to the tank and start the engine to verify that the fuel line is properly installed. Observe the fuel line for any signs of leaks or irregularities while the engine is running.
6/28/2023 2:55:37 AM •
Ryobi Garden
Answered
on Jun 28, 2023
My ryobi weedeater head stopped spinning. I took apart where shaft connects and lower drive is broken off about and inch. Is that repairable ?
If the lower drive of your Ryobi weed eater has broken off about an inch, it may be possible to repair it. However, the extent of the damage and the specific model of your weed eater can affect the repairability. Here are a few steps you can take to assess the situation:
1. Examine the broken piece: Carefully inspect the broken lower drive and determine if it can be reattached or if it requires replacement. Look for any other damaged components as well.
2. Check for replacement parts: Visit the official Ryobi website or contact their customer support to check if they offer replacement parts for your specific model. If the broken lower drive is available as a separate part, you can order it and replace the damaged one.
6/19/2023 9:19:29 AM •
Ryobi Garden
Answered
on Jun 19, 2023
