20 Most Recent
Bratt Decor Jane Crib Questions & Answers
How do you put up the matress
You can call Products America at 800-205-9642 or 800-772-1041. We offer a wide verity of hardware and instructions for many cribs.
Who has good methods to select a good coil spring mattress?
Coil spring mattresses are the best mattresses. They're bouncy plus relives pressure points. Thus, reduce pain and gives a soothe sleep. A person who is deprived of peaceful sleep due to back pain or spine ache can prefer this. I have used coil spring mattress from multiple brands but perfectly satisfied with wakeup's mattress.
Click here : https://mywakeup.in/
3/27/2024 2:33:42 PM •
Baby Gear
Answered
on Mar 27, 2024
Hiw do I get the back off a pottery barn pocket watch clock that has no screws.?
With tread you see dents round the back cover, where an adjustable tool with three pins that could be adjusted to size fits in. When there is no such sign there must be a small latch where a very thin knife goes under and I wish you best of luck, not to break the knife or hurt your self with it. The back should also suddenly break loose. It is not for every body to try attempt this. Wear glasses and gloves. Look for the very thin rubber seal that makes the watch more or less water resistant. It has to go back in place and keep it on when you can.
1/14/2024 9:41:01 AM •
Baby Gear
Answered
on Jan 14, 2024
I need instructions for Natart Rustico to make a crib and to make a bed All parts disassembled and mixed A parts list for each would be great also
I'm sorry, but I don't have access to specific assembly instructions or parts lists for the Natart Rustico crib and bed. However, I can provide you with some general guidance on assembling cribs and beds based on common practices. Please note that these instructions are general, and you should refer to the specific assembly manual that came with your Natart Rustico furniture for accurate details.
General Steps for Assembling a Crib:
- Sort and Identify Parts:
- Lay out all the disassembled parts and sort them according to their shapes and sizes. Identify key components, such as crib sides, mattress support, hardware, and any decorative elements.
- Follow the Manual:
- Refer to the assembly manual that came with your Natart Rustico crib for specific instructions. The manual typically includes step-by-step guidance and illustrations.
- Assemble the Frame:
- Start by assembling the main frame of the crib. Connect the crib sides to the headboard and footboard using the provided screws and bolts.
- Attach Mattress Support:
- Install the mattress support platform according to the manufacturer's instructions. This usually involves attaching it to designated points on the crib sides.
- Secure All Connections:
- Tighten all screws and bolts securely. Ensure that the crib is stable and does not wobble.
- Install Drop-Side Mechanism (if applicable):
- If the crib has a drop-side, follow the instructions carefully to install the mechanism securely.
General Steps for Assembling a Bed:
- Identify Parts:
- Lay out all the parts for the bed and identify the headboard, footboard, side rails, support slats, and any additional components.
- Use the assembly manual provided by Natart for specific instructions. Follow the steps outlined in the manual for your particular bed model.
- Begin by connecting the headboard and footboard using the provided screws and bolts. Attach the side rails to complete the basic frame.
- Attach Support Slats:
- Install the support slats according to the manufacturer's instructions. The slats typically provide support for the mattress.
- Ensure that all screws and bolts are tightened securely. Check the stability of the bed frame.
- Attach Additional Components (if applicable):
- If there are additional components, such as decorative elements or storage features, attach them according to the instructions.
Parts List:
For a precise parts list, please refer to the assembly manual that came with your Natart Rustico crib and bed. The manual should include a detailed list of all components with corresponding part numbers.
If you do not have the assembly manual, you may contact Natart directly or check their official website for customer support. They should be able to provide you with a replacement manual or offer guidance on assembly.
Always follow safety guidelines when assembling furniture, and if you're unsure or uncomfortable with any step,
1/5/2024 9:29:20 PM •
Baby Gear
Answered
on Jan 05, 2024
Pregnancy
What do you mean by "you haven't got it". When is your period due?
I'm afraid you can't really go by "signs", as every woman is different. Some have typical symptoms and others have none. The best way to find out if you may be pregnant is to obviously take a pregnancy test. You can take an early detection pregnancy test such as First Response.
1/4/2024 3:01:20 PM •
Baby Gear
Answered
on Jan 04, 2024
Automotive Glass installation
Put first rubber seal on the glass and fit a thin rope all around the seal with rope ends come out at middle downside. Let glass (with seal fitted on it) sit down side of car window, and pull rope ends from inside the car, while someone pushing the glass from outside to help seal fit on window edge.
12/18/2023 10:56:28 AM •
Baby Gear
Answered
on Dec 18, 2023
