20 Most Recent
Merritt USA Rainbow Pearl Stem Acrylic Stemware Champagne Glasses Set of 12 Questions & Answers
Karcher Puzzi 100 Spray pressure low
1. CHECK THE WATER SUPPLY: MAKE SURE THE WATER SUPPLY IS ADEQUATE AND NOT BLOCKED.
2. CLEAN THE NOZZLES: CHECK THE NOZZLES FOR ANY BLOCKAGES OR DEBRIS AND CLEAN THEM THOROUGHLY.
3. ADJUST THE PRESSURE SETTINGS: ENSURE THAT THE PRESSURE SETTINGS ON THE MACHINE ARE CORRECTLY ADJUSTED.
4. CHECK THE HOSES: INSPECT THE HOSES FOR ANY KINKS OR BLOCKAGES THAT MAY BE RESTRICTING THE WATER FLOW.
5. CONTACT CUSTOMER SUPPORT: IF THE ISSUE PERSISTS, CONTACT KARCHER CUSTOMER SUPPORT FOR FURTHER ASSISTANCE.
3/28/2024 10:15:14 AM •
Dishwashers
Answered
15 hours ago
DIO3T131FEUK Integrated dishwasher has power but won't switch on
1. CHECK IF THE POWER CORD IS PROPERLY PLUGGED IN AND THE POWER SUPPLY IS WORKING.
2. MAKE SURE THE DOOR OF THE DISHWASHER IS FULLY CLOSED AND LATCHED.
3. CHECK THE CONTROL PANEL FOR ANY ERROR CODES OR INDICATORS.
4. TRY RESETING THE DISHWASHER BY TURNING OFF THE POWER SUPPLY FOR A FEW MINUTES AND THEN TURNING IT BACK ON.
5. IF NONE OF THE ABOVE WORK, THERE MIGHT BE A FAULTY CONTROL BOARD OR WIRING ISSUE THAT NEEDS TO BE ADDRESSED BY A PROFESSIONAL TECHNICIAN.
3/28/2024 10:12:54 AM •
Dishwashers
Answered
15 hours ago
WINTERHALTER MODEL MTR3 GIVE ME ERROR 22.2 AND ERROR 12.1
ERROR 22.2:
- CHECK THE WATER INLET VALVE FOR ANY BLOCKAGES OR DAMAGE
- ENSURE THE WATER PRESSURE IS ADEQUATE
- VERIFY THE WATER INLET SOLENOID IS FUNCTIONING PROPERLY
ERROR 12.1:
- INSPECT THE DRAINAGE SYSTEM FOR ANY OBSTRUCTIONS
- MAKE SURE THE DRAIN HOSE IS NOT KINKED OR CLOGGED
- CHECK THE DRAIN PUMP FOR ANY MALFUNCTIO
3/28/2024 10:11:51 AM •
Dishwashers
Answered
15 hours ago
What year is this Kenmore dishwasher Model # 665.15831791 made?
The date of manufacture is determined by the SERIAL NUMBER on the appliance. This dishwasher was manufactured by Whirlpool. The following link explains how to determine when it was manufactured:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The serial number is usually located somewhere around the door opening. The first two numbers in the serial number identify the WEEK it was manufactured (52 weeks in a year). The second DIGIT in the serial represents the YEAR it was manufactured.
If you have difficulty determining the manufacture date, please post back with your serial number and I will assist you. I hope you find this information helpful.
3/12/2024 6:43:46 PM •
Dishwashers
Answered
on Mar 12, 2024
Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
2/4/2024 12:34:17 PM •
Dishwashers
Answered
on Feb 04, 2024
