Quasar HQ2051TH Air Conditioner
Problems with Quasar HQ2051TH Air Conditioner?
Troubleshooting and Support
Solved Problems for Quasar HQ2051TH Air Conditioner RSS Feed Post a New Problem
Is there a fuse or reset?
My AC doesn't run at all. There is power at the outlet, but even the fan doesn't run. I can hear the thermostat click,...
1 Solution
hunter thermostat
i need to know how to put it on cool from heat without using the reset button
1 Solution
Honeywell T8000C Thermostat Problem
Came back from a vacation and found the downstair thermostat's display blank. I tried all - reset breaker, reseat the...
1 Solution
heater lights for about 5 sec and then...
when you turn on the heat to my ruud package unit the ignitor lights the flame and then it goes out after about two...
1 Solution
Leak repair Samsung window air conditioner
Model AW08ECB7 Samsung air conditioner. In attempting to drill a hole in the frame to allow the water to drain, I...
1 Solution
Amana 80SSE Furnace
We have an Amana 80SSE Furnace. The furnace came on by itself when the thermostat was turned off. It was blowing cool...
1 Solution
Sanyo 12KS71 Split Air Conditioner
Installed in 5/07, ran fine for 3 months, then it would not start - no lights, nothing. Reset breaker and it ran fine,...
1 Solution
Unsolved Support Problems
Unsolved Problems for Quasar HQ2051TH Air Conditioner RSS Feed Post a New Problem
Removing l-shaped Quasar window air...
I have a Quasar window air conditioner of the type that has the body below window sill level with just a slim air vent...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Other Features
Moisture Removal (Pt/h)1.4
FilterReusable
Air Flow140 cfm
ENERGY STARWith ENERGY STAR®
Key Features
TypeThru-Wall/Window
Cooling Capacity5200 BTU/hr
Energy Efficiency Rating9.7 EER
Fan Speeds (Cooling)2
Electrical Requirements
Voltage115
Cooling Ampacity5
Heating Watts540
Dimensions
Depth19.69 in.
Height12.28 in.
Width18.56 in.
Quasar Contact Information
Main support number08717 177 168
Sponsored Links
Loading problems.
Top Experts
Ask Me
koolbreez Wiz
16 solutions
Ask Me
spam_here Guru
6 solutions
Ask Me
WesR68 Wiz
6 solutions
Repair Service
Find Air Conditioner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
