20 Most Recent LG Studio Series LSVC302ST Questions & Answers
Exhaust fan just installed not working
Did you have it professionally installed? I would suggest contacting the manufacturer to see if the issue is under warranty. You can find the support page here: http://www.lg.com/us/support-product/lg-LSVC302ST#
12/23/2013 9:56:49 PM • LG Studio Series... • Answered on Dec 23, 2013
Cannot set oven temp on LG Electric Range (LSEL6335)
Possibly the number pad is faulty and requires replacement.
7/20/2022 6:08:28 PM • LG Kitchen... • Answered on Jul 20, 2022
How to replace d shaped shaft that holds knob
shaft is integrated into the control whole control needs replacement
7/6/2021 2:43:07 PM • LG Kitchen... • Answered on Jul 06, 2021
LRE3085ST range. Why does it take a long time to preheat oven to 350 deg.?
check gas pressure to unit if ok possible blocked burner
1/12/2021 5:13:35 AM • LG Kitchen... • Answered on Jan 12, 2021
LG electric range
It appears that the circuit board behind the knobs has failed.
12/16/2019 1:49:07 PM • LG Kitchen... • Answered on Dec 16, 2019
I have a lg electric range around 6yrs old im getting an f11 error code. the oven wont heat up
https://www.lg.com/us/support/help-library/error-codes-cooktop-and-range-CT00000303-20150154166283It says if you it comes back after you clear the error then to call for servicehttps://www.fixya.com/support/t7390204-getting_f11_error_message_our_new
11/20/2019 7:42:11 PM • LG Kitchen... • Answered on Nov 20, 2019
3answers
Brand new LG electric range - convection fan stopped working LRE3061BD? I have a one year standard warranty. HELP - Bought it from Lowe's 9/30/2017
Hello, Stephen - Call you local Lowes and find out if they will send a repair person to fix the range. They may wish you to produce the sales receipt for the range to prove it is under warranty. Best wishes
10/26/2019 4:51:42 PM • LG Kitchen... • Answered on Oct 26, 2019
Lg STOVE SOME TIME COMES f11 code AND SOME TIME MAY TAKE ABOUT 1 HOUR AND HEAT STAY IN SAME NUMBER 200-220 Thanks
Hi, an f11 code means it's taking too long to heat up. Problem is most likely a worn bake ignitor. It's not drawing enough amps to open the gas safety valve. Call your local repair company. Hope that helps.
10/2/2019 6:20:17 PM • LG Kitchen... • Answered on Oct 02, 2019
How to remove door on LG range model lre3023st
To remove the door on the LRE3023ST, fully open the door. Pull the hinge locks down towards the door frame to the unlocked position; you may find a flat blade screwdriver helps to lever the locks to start the process. Grasp the door at the sides near the top with both hands. Tilt the door up to about 5 degrees from the closed position. Lift the door up and out until the hinge arm clears the slot where the hinge point locks onto the oven frame on both sides. Put the door down. This is shown on page 32 of the Owner's Manual. LG has this on the product support page: https://www.lg.com/us/support-product/lg-LRE3023ST#manuals . The direct link to the manual seems to be http://gscs-b2c.lge.com/downloadFile?fileId=KROWM000460684.pdf . I hope this helps. Cindy Wells
3/25/2019 6:08:52 PM • LG Kitchen... • Answered on Mar 25, 2019
LG Cooktop Ceramic Stove It keeps beeping(4-5 beeps) every 5 minuted while on and off I tried shutting off stove at Breaker for a day Keeps beeping Any idea how to stop this beeping? Thanks
Try the LG website, under support, user manuals. Find the one you need and maybe it will help.
1/16/2019 12:37:55 PM • LG Kitchen... • Answered on Jan 16, 2019
LG Electric Range model LRE30453ST; convection fan has begun rattling continuously & squeaking intermittently. Please help.
LG Range/Stove/Oven Convection Motor EAU60722701 RepairClinic Item #1594786 ' LG OEM Part #EAU60722701 Convection Motor EAU60722701
12/22/2018 7:25:41 PM • LG Kitchen... • Answered on Dec 22, 2018
2answers
LG Studio Series LSVC302ST Logo
1 questions posted
Top LG Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
LG Kitchen Ranges
  • LG Kitchen Ranges
Most Popular Question
exhaust fan just installed not working
  • Kitchen Ranges
