20 Most Recent
Sears Parts Direct Filtr-pump - 9742968 Questions & Answers
Can't get dishwasher out from underneath the counter
Question edited to move it from Computers to Dishwashers.
Is there by any chance a floor tile 4" out from the dishwasher front? If so, try lifting the front with a crowbar or long screwdriver.
Did you disconnect, inlet hose, drain and power? They may have been installed tight, or clipped.
4/19/2024 6:24:59 PM •
Dishwashers
Answered
5 hours ago
HOW TO REPAIR A HOLE IN MY DISHWASHER
It depends upon the material you are trying to repair but Araldite or any good quality two part epoxy will suffice to fill the hole.
Ensure the area is dry and clean then build up the repair . Larger holes will require multi additions of epoxy.
4/15/2024 10:01:23 PM •
Dishwashers
Answered
on Apr 15, 2024
WINTERHALTER MODEL MTR3 GIVE ME ERROR 22.2 AND ERROR 12.1
These error messages both point to a sensor problem.
Error 12.1
This error is related to the boiler temperature sensor. Consider the following:
Look for a short circuit in the sensor. Inspect the cables and plugs for any issues.
Ensure the sensor is correctly connected.If needed, replace the boiler temperature sensor.
Error 22.2:
This error pertains to the tank temperature sensor. Possible causes include:
Short circuit in the sensor.
Cable failure or plug failure.
Sensor not properly connected.
You may need to check the sensor wiring, connections, and replace the temperature sensor if necessary.
4/3/2024 6:11:13 PM •
Dishwashers
Answered
on Apr 03, 2024
What year is this Kenmore dishwasher Model # 665.15831791 made?
The date of manufacture is determined by the SERIAL NUMBER on the appliance. This dishwasher was manufactured by Whirlpool. The following link explains how to determine when it was manufactured:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The serial number is usually located somewhere around the door opening. The first two numbers in the serial number identify the WEEK it was manufactured (52 weeks in a year). The second DIGIT in the serial represents the YEAR it was manufactured.
If you have difficulty determining the manufacture date, please post back with your serial number and I will assist you. I hope you find this information helpful.
3/12/2024 6:43:46 PM •
Dishwashers
Answered
on Mar 12, 2024
Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
2/4/2024 12:34:17 PM •
Dishwashers
Answered
on Feb 04, 2024
