20 Most Recent
Crown CE1000 2-Channel Amplifier Questions & Answers
3055 transistor short
How do you know it is shorted. What is the full part number, that number is on transistors, MOSFETS and a few other things.
Bridged
setup of bridge mono mode:-1-turn your amplifier off.2-connect input wiring to channel(1) input--3-connect speaker across positive outputs terminals-do not use negative terminal when amplifier is operating in bridge mono mode.4-turn down (fully counter clockwise)of channel (2).
Without any audio source or speakers on output
It's very likely that the main power amp section has a faulty part on it that is presumably causing an overload. You should check the devices on the main heat sink of the amp section.
Why fan stop working
If the fan is not working, it could be the fan itself, or it could be missing the voltage to drive it. I wouldn't use the amp with this condition, as you may cause output failure. If you need more information, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
2 speakers and 1 powered sub
The red and black connectors are the right (red) and left channels for the speakers, so they should connect. However the sub needs a single RCA type phono socket, which should be marked "sub" etc. If it hasn't got one of them you will have problems connecting the powered sub.
I need circuit diagram for amplifier
http://elektrotanya.com/crown_ce1000_ce2000_ce_series.pdf/download.htmlclick on the download link on the right next to the manual frontpage picture
I recently dropped my amp after a gig and once I
I am a musician myself (classic rock band) I too have a crown two Chanel amp , only difference is ours is a 3000. Well don!t feel bad. I had dropped mine more than once and your right, when you turn it on you hear two clicks, one for each side, those are relays that trigger the power to come on and like warm up. I dropped mine one time and both sides were not clicking at all, so I took it apart ( lid off, unplugged of course) located the relays which were pretty easy to find as they were the first switch from where the internal power plug comes in, I moved them around, got lucky, they got loose from when I dropped. Then happened again by a helper, and this time no help. Went to guitar center and they took unit and replaced them, about 40 bucks. That was a couple years ago. Point of my story, this problem seems as mine, and I believe it is going to be a loose or broken relay for that side chanel. Thanks mike, hope this helps.
The left channel of the
make sure the olug in is very tight and the wiring has a solid connection. If not feedback of this sort is very common
It clips as soon as
I actually had a similar problem with a couple of the 2000w version (band was running two 2000w crowns PLUS another 500w JVC for the sub). We replaced the reset button, and that did the trick, until they completely wore out a few years after that (constant use is harsh on these...).
Hope that helps! Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/cameron_463100ffd54b591d
How many amps ?
To determine the current draw (assuming near-unity power factor), divide the input power wattage printed on the back of the amplifier by the line voltage.
