20 Most Recent
Amana RCS10TS - Commercial Microwave Oven - 1000 Watts Questions & Answers
Amana bottom freezer, all working OK, but very noisy freezer. How do I fix it?
There are a few potential causes of a noisy bottom freezer. Here are some things you can try to fix the problem:
- Check for frost buildup: Frost buildup can cause the freezer to become louder as it has to work harder to keep things frozen. To check for frost buildup, remove all items from the freezer and unplug the fridge. Then, use a hair dryer to melt any frost that has accumulated on the evaporator coils (usually located behind the back panel of the freezer).
- Check for loose parts: Some common sources of noise in a freezer are loose screws, washers, or other small parts. Check for any loose items and tighten them as needed.
- Check the evaporator fan: The evaporator fan is responsible for circulating air within the freezer. If the fan is not working properly, it can cause the freezer to become noisy. You can check the fan by removing the back panel of the freezer and listening for any unusual noises. If you suspect the fan is the problem, you may need to replace it.
- Check the compressor: The compressor is responsible for circulating refrigerant and cooling the freezer. If the compressor is malfunctioning, it can cause the freezer to become noisy. You can check the compressor by listening for any unusual noises or by checking the compressor with a multimeter. If you suspect the compressor is the problem, you may need to replace it.
If you are unable to fix the problem yourself, you may want to consider contacting a repair service. They will be able to diagnose and fix the issue more accurately.
Frost builts up in the coils
Frost will normally build up if you do not have frost free freezer and in which case it is possible the frost free system is faulty. If it is not frost free then it has to be defrosted a few times in a month. However if the frost comes up very quickly then there are possible causes.
You may be having leakage from the door seals or there are items in the freezer that are not properly covered to avoid moisture escaping. Other possibility is that your freezer is set too cold and there are not many items in it.
Frozen water on the bottom of my Amana freezer
Your drain line is clogged. Take a small diameter pice of wire and snake out the drain line from inside the freezer.
You may have to access the back rear near the compressor and separate the drain line there and clean it further.
