20 Most Recent Samsung RSG309AARS 30 cu. ft. Side by Side Refrigerator in Real Questions & Answers
replace the lower plastic shim on the hinge
Samsung... | Answered on Feb 21, 2014
call a repair tech it possibly needs freon added .
Samsung Freezers | Answered on Dec 02, 2017
They generally use 1/4" tubing.
Samsung Freezers | Answered on Oct 23, 2017
Check the thermostat, and the cooling fluid.
Tao the thermostat en see if it will start the compressor. When you hear the compressor running and still no cooling, you must have lost the cooling fluid. (used to be freon)
Samsung Freezers | Answered on Apr 05, 2017
Hello Danie;
My name is Peter. I am a retired field service refrigeration technician.
The normal setting for a freezer is -2 to +2 degrees F., and the normal setting for the fresh food section is +35 to +40 degrees F.
You only have one source of cooling and that is your freezer. With the settings that you have, you are asking your unit to do what it is not designed to do.
The ice maker is struggling because if it is a cast steel ice cube mold, the heater beneath it is not designed for the current to break the ice cubes free @ -18 degrees F., or if you have a plastic flex ice cube mold it is too ridged to flex enough to break the ice cubes free. Normally your ice maker should dump 8-10 times in a 24 hour period.
A note on food storage. Make sure you do not overload your freezer of fresh food section to the point where food product extends beyond the edge of the shelves.
It should be on the right, front or back:. I can see a dipstick from the bottom up on the front right on the first video and on the pickup, maybe it is the same engine, at the right rear.
also you can join a largo group at largo friends
How to check and add oil on 1995 Nissan Pickup Truck 1989 2000 Project Nissan Largo retimed first start
Nissan Largo Friends
Samsung Freezers | Answered on Apr 29, 2016
Hello;
Your problem is not your thermostat. In some models the compressor knocks out the overload relay. They relay could last a few seconds or a few weeks before the compressor knocks it out again. This is especially turn with the LG units.
You will need a multi-meter to check your compressor.
1.) Unplug your unit. Remove the bottom back cover.
2.) Remove the overload components to expose the 3 pins on the compressor.
3.) Inspect the pins on the compressor. Are they clean or are they damaged from heat (Steel melting).
4.) With your multi-meter, set the meter on the lowest Ohms. Read the Ohms between each of the pins. You will have 3 readings. One reading will be high and the other 2 readings will be lower. Add the 2 lower readings together. This value must equal the high reading within a few tenths.
I hope I am wrong. A new compressor depending on the model is $275-$450.00. Include a system filter for $40.00, plus new refrigerant $45.00 and the cost od an experienced technician $300.00.
Samsung Freezers | Answered on Dec 04, 2014
There is a drain tube located under the panel of most freezers. If that clogs up, the auto defrost can't work. The freezer defrosts by evaporating all the moisture out of the compartment. So, check that first. Secondly, a leaky door seal can also cause that problem. You can order door seals online or on Amazon.
Samsung Freezers | Answered on Oct 17, 2014
www.samsung.com/us/support/downloads
Samsung Freezers | Answered on Jun 30, 2014
I am not familiar with that unit but I assume you are talking degrees C. There should be a thermostat you can change. It may already be at the coldest setting, I do not know. Most of these units have a minimum temperature they will operate at, if you are at that point you will have to either change the thermostat or modify it in either case it would void the warranty.
Samsung Freezers | Answered on Apr 29, 2014
Samsung RSG309AARS 30 cu. ft. Side by Side Refrigerator in Real Logo
1 questions posted
Top Samsung Freezers Experts
Jay Finke
Jay Finke
ray gallant
ray gallant
Michael Youngman
Michael Youngman
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
View Most Popular
Samsung Freezers
  • Samsung Freezers
Most Popular Question
freezer door drops slightly makes clunk
  • Freezers
