20 Most Recent AudioCodes MediaPack MP-118-FXS Router (MP118FXSC3S) Questions & Answers
0answers
0answers
Fail light is on
Be the first to answer 12/16/2010 1:30:12 AM • AudioCodes... • Posted on Dec 16, 2010Be the first to answer
0answers
Pls how can i reset my audiocode mp-118 back to
First of all unplug the network cable.
Then take a pin or a needle and insert it into the pin whole which is intended for reset. Insert the pin inside the pin whole and press at least for 6 seconds. All the LEDs (Light emitting diodes) or the tiny lights will glow brighter while the reset button is being pressed by the pin. The device will reset. After reset the red LED may start to blink bright.Be careful and be patient as all the LEDs are normal before you plug in the network cable.
Good Luck!
7/26/2010 11:16:54 AM • AudioCodes... • Answered on Jul 26, 2010
0answers
AudioCodes MP-252 bw login user name and password ?
Yes. Log in with user name, password, bank account number, Credit card number and password used at the bank, Name, address of yours, date of birth, name of bank. Give all the details with ease.
8/14/2016 12:46:47 PM • AudioCodes... • Answered on Aug 14, 2016
0answers
0answers
How do i change the
The internal, LAN-IP address is normally set to a default, private number. Linksys routers, for example, use 192.168.1.1 for their internal IP address. D-Link and Netgear routers typically use 192.168.0.1. Some US Robotics routers use 192.168.123.254, and some SMC routers use 192.168.2.1. No matter the brand of router, its default internal IP address should be provided in documentation. Administrators often have the option to change this IP address during router setup. In any case, however, the private LAN-IP address remains fixed once set. It can be viewed from the router's administrative console.
The external, WAN-IP address of the router is set when the router connects to the Internet service provider. This address can also be viewed on the router's administrative console. Alternatively, the WAN-IP address can be found by visiting a Web-based IP address lookup service like http://checkip.dyndns.org/ from any computer on the home LAN.
Another way to identify the public IP addresses of routers, involves executing a ping or traceroute command. From inside a home network, the (DOS) command "ping -r 1" will send a message through the home router that will cause its IP address to be displayed. For example, "ping -r 1 www.yahoo.com" should result in a message like the following displayed on the command prompt:
To change router password Open your Internet browser, type the address of the router into the URL address bar, and open it. The address is typically in the form of 192.168.X.X. This is the local network address. Enter the account name and password to open the router setup utility. Navigate through the setup utility until you find the screen that will let you change the password. You will need to enter the old password to change it. Decide on a new password that has good security to a hacker. The best password is more than 8 characters and uses both lower case and upper case letters and numbers. Some will allow you to use special characters also. Do not make the password anything that can be found in a dictionary or any date of significance. Enter the old password in the change password page of the router. When prompted then enter the new password. You will be asked to enter it twice to confirm that the correct password is entered. Immediately, record the new password in some secure location that you can find if you forget it. Confirm the password change on the router page and log off the router. To check the information and that the router has been setup correctly with the new password, open the router address in the browser again and login with the new information. If you are able to login, you have successfully changed the password. Network: Router Ssl Vpn
12/25/2010 2:45:46 PM • AudioCodes... • Answered on Dec 25, 2010
Where can i get mastering machine learning Tips for Tackling Assignment
Here
The Ultimate Guide to Conquering Machine Learning ...
makexyz.com https://www.makexyz.com > the-ultimate-guide-to-conqu... Feb 19, 2024 - When diving into machine learning assignments, it's essential to adopt a systematic approach. Break down the task into manageable components, ...
7 Steps to Mastering Machine Learning with Python in 2022
KDnuggets https://www.kdnuggets.com > 2022/02 > 7-steps-masteri... Sep 30, 2022 - Step 1: Learn Programming for Machine Learning ... You need to have a working knowledge of programming before you dive into machine learning. Most ...
Machine Learning Assignment Help
Medium ยท Abnerassignmenthelp 1 month ago Our experts can assist you in tackling machine learning assignments effectively. Deep Learning Assignment Help: Our team of deep learning . ..
4/24/2024 5:58:44 PM • Computers &... • Answered 2 hours ago
3answers
How do I find The best Roofing Service Contractor in Houston, Texas?
To find the best roofing service contractor in Houston, Texas, ask for recommendations from locals, check online reviews, verify licenses and insurance, and interview multiple contractors. Trust your instincts and choose wisely.
4/24/2024 4:31:29 AM • Computers &... • Answered 15 hours ago
AudioCodes MediaPack MP-118-FXS Router (MP118FXSC3S) Logo
7 questions posted
Top AudioCodes Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an AudioCodes Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • AudioCodes Computers & Internet
Most Popular Question
pls reset audiocode mp 118 back
  • Computers & Internet
