FixYa.com
DB Drive A300 Car Audio Amplifier
All Products > DB Drive > Car Amplifiers
Problems with DB Drive A300 Car Audio Amplifier?
Search inside DB Drive A300 Car Audio Amplifier Knowledgebase
Troubleshooting and Support
Solved Problems for DB Drive A300 Car Audio Amplifier RSS Feed Post a New Problem
I have a new receiver with a preamp...
I have a new receiver with a preamp output, high volume, and I want to feed that into my power amp. Do I need to...
1 Solution
I´ve got 2 amps for my subs,but only...
I´ve got 2 amps for my subs,but only one pre-out from HU of course.i know i should be using amp´s line out to...
1 Solution
Can I hook up an amplifier to my factory...
Can I hook up an amplifier to my factory radio?
1 Solution
Problem
I am having trouble keeping my amp on when I turn up my stereo. I am running it in stereo setting on the LPF and I have...
1 Solution
american legacy II LA690 amp
i want to know if there is any way you can bypass the overhaul (green light:power, red light:overhaul) because when ever...
1 Solution
Need a power connector for a Boss IQ 3KD.1...
Where can I find a replacement power connector for a Boss IQ 3KD.1 3000W Class D Monoblock Amplifier. The screw loosened...
1 Solution
Blown Amp
Whilst wiring my stereo in i touched the earth and live onto the live and blew part of the gold leaf connection inside....
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Amplifier TypeMono Channel
BridgableBridgable
Power Output
RMS Power at 4 Ohms150 W x 1
RMS Power at 2 Ohms300 W x 1
Performance
THD at Rated RMS Power0.5 %
Signal to Noise Ratio95 dB
Frequency Response20 Hz - 28000 Hz
Other Features
MOSFET ampYes
Input Voltage11 volt
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
