20 Most Recent Raymarine Ray54 Vhf Marine Radio Dark Grey Questions & Answers
Where can I buy a
Sadly, the mic and cord for the Ray54 have been discontinued by the manufacturer. I guess if you plan to buy a Raymarine VHF, your best bet would be to buy a spare radio for parts. Unbelievable. Here's the link to that conversation from Raymarine support. I realize this question is old, but the information could be helpful to someone else. -Steve Raymarine 54 Mic Chord
1/15/2015 7:09:09 PM • Raymarine Ray54... • Answered on Jan 15, 2015
Parts for Ray54
Sorry. Replacement cords for the Ray 54 are no longer available according to the Raymarine support forum. Here's the link: -Steve http://raymarine.ning.com/forum/topics/ray-54-replacement-microphone-cord
1/15/2015 3:49:41 PM • Raymarine Ray54... • Answered on Jan 15, 2015
Need a replacement cable for ray 230
Hi For your 230, you need part number R49085 which should be able to be ordered by any Raymarine dealer. On the link below, scroll down to post #8. Hope this helps you out. -Steve Ray 240 VHF how to obtain new cord
1/15/2015 3:45:51 PM • Raymarine Ray54... • Answered on Jan 15, 2015
2answers
Need to install new MMSI number
You cannot change the MMSI number yourself, you have to go to an authorized service retailer to have it changed.
10/15/2014 8:42:18 PM • Raymarine Ray54... • Answered on Oct 15, 2014
Where is the ray49 vhf radio serial number located?
its on the label on the underside of the unit. It will probably begin with E43035.........
2/6/2013 6:24:09 PM • Raymarine Ray54... • Answered on Feb 06, 2013
I need the sequence to remove the MMSI number that
only a Raymarine dealer can delate the MMSI number with a Sofware
10/15/2009 1:30:31 PM • Raymarine Ray54... • Answered on Oct 15, 2009
The Raymarine ST8002 Smartpilot the unit powers up but does not work when the auto mode is selected. The hydraulic motor does not engage when a course is set. What could be the source of the fault?
According to a post on the Raymarine forum, this error message could indicate an issue with either the steering, the drive unit, the rudder reference unit (if fitted), or the course computer . The post suggests a few tests that you can do yourself to figure out which item is causing the issue. I suggest that you try the following steps: Check the connections between the ST8002 SmartPilot and the other components of your autopilot system. Check the calibration of the ST8002 SmartPilot and the other components of your autopilot system. Check the hydraulic fluid level and the hydraulic pump pressure. Check the hydraulic pump motor and the hydraulic pump solenoid valve. If none of these steps work, I recommend that you contact Raymarine customer support for further assistance.
11/20/2023 9:03:39 PM • Raymarine... • Answered on Nov 20, 2023
How do I connect my garmin 741sx with my raymarine St 4000 with nmea 183
To connect your Garmin 741sx with your Raymarine ST 4000 using NMEA 183, you will need an NMEA 0183 interface cable to connect the two devices. Here are the steps to follow:
  1. Obtain an NMEA 0183 interface cable that has the correct connectors for your Garmin 741sx and Raymarine ST 4000.
  2. Connect one end of the NMEA 0183 interface cable to the NMEA output of your Garmin 741sx.
  3. Connect the other end of the NMEA 0183 interface cable to the NMEA input of your Raymarine ST 4000.
  4. Configure your Garmin 741sx to output NMEA 0183 data. Refer to your Garmin 741sx manual for instructions on how to configure NMEA output.
  5. Configure your Raymarine ST 4000 to receive NMEA 0183 data. Refer to your Raymarine ST 4000 manual for instructions on how to configure NMEA input.
  6. Once both devices are configured, the data from the Garmin 741sx should be transmitted to the Raymarine ST 4000 via the NMEA 0183 interface cable.
2/23/2023 5:01:41 PM • Raymarine... • Answered on Feb 23, 2023
Raymarine C70. Como cambiar la pantalha de modo diurnos a noturno ?? en el Raymarine C70.
Question edited for clarity.Question moved from Cars and Trucks to Raymarine.Adjusting the display lighting The display has two distinct color palettes, for day and night operation. You can alsomanually adjust the backlight level.Note: The display lighting is a local setting and will therefore only affect the individualdisplay on which you are working.Day/night operationTo select the day/night mode of operationhttps://www.manualslib.com/manual/138190/Raymarine-C-Series.html?page=30#manual
8/3/2022 6:36:50 PM • Raymarine... • Answered on Aug 03, 2022
I want to mount a sonar transducer for my raymarine dragonfly-4 on my 16 foot aluminum boat where do I mount it Thank you
on the transom outside of the boat silicone the bolt holes
10/29/2021 12:36:07 AM • Raymarine... • Answered on Oct 29, 2021
Raymarine c120 classic intermittent no data source
"Finally convinced him that **your** specs requiring the 4c cable at those lengths was correct" You know we are Fixya and not Raymarine? We just have a Raymarine category for handy filing of questions and answers. This question needs a factory service department technician on the phone. As a boat owner, who doesn't have radar, and reading your post carefully, I would suggest the connection at the top of the mast. It is far more hostile up there, and it has been up there a long time.
7/10/2021 9:20:46 PM • Raymarine... • Answered on Jul 10, 2021
Need Manual for Navico WP5000
get ie here -
http://hem.passagen.se/beg_stockholm/wheelpilot_manual-no_pic.html
8/3/2018 9:46:52 PM • Raymarine... • Answered on Aug 03, 2018
I have a Raymarine Axiom system on my boat. Can you help me.
Check with Raymarine. Model number would be of use. http://www.raymarine.com/view/?id=10125 Raymarine Manuals Documents
6/21/2018 12:27:41 PM • Raymarine... • Answered on Jun 21, 2018
Raymarine Ray54 Vhf Marine Radio Dark Grey Logo
12 questions posted
Top Raymarine Boating Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
View Most Popular
Raymarine Boating
  • Raymarine Boating
Most Popular Question
need replacement cable ray 230
  • Boating
