20 Most Recent
Minn Kota Maxxum 80 Freshwater Bow Mount With Us2 Questions & Answers
I was using it when all the sudden it just quit
Hey SCOTT ..
Get a multimeter (to check voltage) Verify you have 24 volts coming to the front plug. Now - VERIFY that you are getting 24 volts to the switch. ..All OK..- Now to check the power switch. Disconnect the two wires on the power switch and CAREFULLY connect them by hand.. now SAFELY see if the prop will turn. If the switch is bad, bypassing it will make the prop spin!
..If the prop still does not work,, keep following the voltage.. For more help, trust these guys!:
http://www.jonestrollingmotor.com/
Ticking noise inside motor head
I dont know if this is your problem,but I just took mine apart and the brushs were stuck,cleaned and put back.works like a new on.
I left my minn Kota I pilot turn on will this be harmfull
Hi. I believe you are referring to a Minn Kota with i-Pilot GPS? If you forget to turn the power button off and the motor was not running (meaning the prop was not turning), your motor should be fine. Ultimately, if left on for long enough, it will drain the batteries and eventually turn off. This is not harmful for the motor.
For safety reasons (yourself and others), it's always best to disconnect the motor from the power source when not in use.
1/14/2024 10:12:39 PM •
Minn Kota...
Answered
on Jan 14, 2024
I have a Minn Kota Traxxis 80, the proble is the extending handle free slides and is an irritation. Is ther a way to tighten the sliding extension.
Yes, there is a way to tighten the sliding extension on the Minn Kota Traxxis 80 handle. Here are the steps to follow:
- Locate the set screw: Look for a small set screw on the side of the handle where the sliding extension meets the stationary part of the handle. This screw is typically located on the underside of the handle and may require a small tool to access.
- Tighten the set screw: Using the appropriate tool, tighten the set screw by turning it clockwise. This will secure the sliding extension in place.
- Test the handle: After tightening the set screw, test the handle to make sure it is secure and does not slide freely. If necessary, adjust the set screw again until the handle is secure.
- Reassemble the handle: Once the sliding extension is tightened, reassemble the handle by replacing any covers or trim pieces that were removed to access the set screw.
Remember to use caution when working with small screws and tools, and to follow any safety guidelines provided by the manufacturer.
2/24/2023 1:55:43 PM •
Minn Kota...
Answered
on Feb 24, 2023
I have a Minn Kota 315D 3 bank charger. When I plug it in to my electrical outlet only bank 1 shows a solid yellow light. I am not getting power to bank 2 and 3.
A solid yellow light on Bank 1 of your Minn Kota 315D 3 bank charger indicates that the charger is in "float" mode, which means it is maintaining the battery's charge at a safe level. It sounds like there may be an issue with the connections or wiring for Banks 2 and 3, preventing them from receiving power.
Here are a few things you can try:
- Check the connections between the charger and the batteries for Banks 2 and 3 to ensure they are tight and secure.
- Ensure that the circuit breaker for the charger is not tripped.
- Check the wiring for Banks 2 and 3 for any visible damage or corrosion.
- Ensure that the batteries for Banks 2 and 3 are not in a low state of charge or are not faulty.
- Try to reset the charger by unplugging it from the power source and plug it back in after a few minutes.
1/20/2023 10:20:52 AM •
Minn Kota...
Answered
on Jan 20, 2023
