20 Most Recent
Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor Questions & Answers
I have a riptide st 80 24 volt bow mount co-pilot.
Start to look for the charge state of your battery.
Measure the voltage on the battery connectors when the motor falls out. If lower than 11v your battery is too weak.
Also check all the cables between battery and motor. Check foor loose connection or oxidation.
9/25/2017 4:59:03 PM •
Minn Kota...
Answered
on Sep 25, 2017
Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
3/28/2013 4:21:55 PM •
Minn Kota...
Answered
on Mar 28, 2013
