20 Most Recent
Minn Kota Riptide Sp Saltwater 70 Bow Mount Trolling Motor With Autopilot Questions & Answers
Minn kota
I have a terrova with i pilot same thing happened found out it was the remote, if thats not it then you will more than likely have to send it in for repair.
6/2/2014 7:35:47 AM •
Minn Kota...
Answered
on Jun 02, 2014
Minn kota will turn on and off with remote, but
take off the top cover on the head of the motor and see if there are any restrictions to the movement of the cable. it may be the cable itself is rusted internally and may need replacement. call min kota on the 800 number on the motor for prices for any patrs you may need.
11/3/2011 8:47:48 PM •
Minn Kota...
Answered
on Nov 03, 2011
The autopilot for my 2006 Minn Kota Riptide 55lb
Some common issue with these are as follows.
The polarity some how got reversed, either when changing batteries or chaging them. A ligning strike can cause an issue like this as well, it doesn't need to hit the boat cause a problem just close by is enough.
There is a magneto that can short out as well, minn kota can supply a replacement if yours is arcing.
Can also be something as simple as the switching relay,, or a bad pin / wire in the plug,, or it could be a bad servo motor.
the best way to trouble shoot the unit would be to open the case and use volt meter to trace the voltage flow. also make sure you are getting power to and thru the remote as I have seen the control buttons go bad.
Take the side panel off the part of the trolling motor that actually is bolted to the bow of the boat--this panel contains a sealed circuit board with a small antenna attached; see if anything looks burnt or otherwise not normal.
Last but not least, are the batteries in the co-pilot good?
3/7/2011 1:10:19 AM •
Minn Kota...
Answered
on Mar 07, 2011
What size wire should i
The new cost of your motor is nearly 1000 dollars, presumably there are comprehensive instructions on installation to minimise the risk of damage which could be very expensive. In particular damage to the motor control circuits due to incorrect fusing.
Do yourself a favour and contact the manufacturers directly
http://www.minnkotamotors.com/service/contact.aspx
regards
3/1/2011 10:58:25 PM •
Minn Kota...
Answered
on Mar 01, 2011
I have the Minn Kota
if it is not steering with the remote - then the problem could be something as simple as the switching relay,, or a bad pin / wire in the plug,, or it could be a bad servo motor.
if you are still having troubles and have more questions - please feel free to write me back here and I will do my best to walk you through the steps needed to fix or trouble shoot more.
have a great night,
c...
2/21/2011 3:44:40 AM •
Minn Kota...
Answered
on Feb 21, 2011
Hey great t motor. Today
Please need more information on this question for me to proffer solution to the question, shed more light on this question, so that i can proffer a solution.
Thank you.
6/23/2010 10:52:23 AM •
Minn Kota...
Answered
on Jun 23, 2010
