20 Most Recent Chevrolet 1999 Chevrolet Tahoe LT Questions & Answers
When i turn the wheel left in 1999 chevy tahoe the exaust and engine revs up realy loud messing up the engine and it starting to get hard to turn left knowing it could mess up.what is wrong with it?
You have air in the power steering lines. Was the fluid low or do you have a leak? Car off, in park, raise your front end, both front wheels off the ground with a floor jack. Start the engine and turn the wheel all the way right and left a couple times. Add more PS fluid if necessary and do it again. Air compresses but the fluid does not. Turning left uses almost all the fluid to push the arm out of the piston. Moving it all the way right will allow the air to escape in the fluid reservoir.
5/2/2016 8:11:47 PM • Chevrolet 1999... • Answered on May 02, 2016
I have a 99 chevy tahoe 4X4 thats giving me problem.when pushing down on brake pedal it pushes back then the ABS light comes on and then the truck starts revving up and not shifting gears right.what c
Sounds like when the problem happens the truck goes into limp home mode in the computer, which would not allow the truck to go over about 30 mph, So when the problem happens you need to put a scanner on the obd link and read the code which will tell what part of the abs system is giving you problems. Hope this helps.
4/27/2016 5:59:34 AM • Chevrolet 1999... • Answered on Apr 27, 2016
The intake manifold gaskets have been change and the distributer has been taken out and put back truck will crank over but will not start like it is not getting a spark
Did you align the rotor in the dist. to #1 cylinder in the firing order if not you will not get fire to spark plugs. Is the unit backfiring when you turn it over or does it just roll over. Let me know.
4/27/2016 5:51:21 AM • Chevrolet 1999... • Answered on Apr 27, 2016
3answers
Vibrates when you get to 60 miles per hour. New tires, new shocks, new tie rods, new brakes, new roters, balanced tires still vibrates when I get to 60
Did you have a front end alignment done? If the tie rods were changed then that could be out. Bad wheel bearing?
11/30/2015 7:57:57 AM • Chevrolet 1999... • Answered on Nov 30, 2015
My heaters only blow hot air when Im driving and give it gas
Are your fluid levels up to where they are supposed to be? If you need further help, I’m available over the phone at https://www.6ya.com/expert/dan_77d17b8918f54455
1/21/2015 2:14:19 PM • Chevrolet 1999... • Answered on Jan 21, 2015
2answers
Have a 1999,Chevy Tahoe that I changed the fuel pressure regulator. After I started loud knock. Why?
As silly as this may sound.....Be sure you have new oil in the crank case. I just brought my Chevrolet pickup home from the shop for a knocking noise. The oil broke down to the point that little compression was the problem. An oil change did work.
1/13/2015 1:49:27 AM • Chevrolet 1999... • Answered on Jan 13, 2015
I have 1999 Chevy Tahoe. 5.7 liter. Changed the fuel pressure regulator and started it knocked loud. I accounted for every but and bolt and nothing got into the intake. What could it be?
Trace your steps, if it wasnt doing it before hand and is doing it after your repair then its something that the repair caused. Check your spark plug wires to make sure they didn't get swapped, and if need be pull each plug and get a pin camera and check each cylinder for debris
1/13/2015 1:47:17 AM • Chevrolet 1999... • Answered on Jan 13, 2015
Gas gauge reads empty or full nothing inbetween jumps from one to the other. I want to know if its the gauge, sending unit, or wiring short
check for shorted wires right where the wires connect to the tank. Dirt and water pile up there and corrode the whole works. Otherwise it will be the sending unit inside the tank.
12/22/2014 4:42:17 AM • Chevrolet 1999... • Answered on Dec 22, 2014
What is E3 in frego split ac
Frego split ac error code h3 what is problem
4/16/2024 4:25:39 AM • Heating &... • Answered 15 hours ago
2answers
What does E2 code mean on electric infrared heater
Model 2320cpb. E2 code
4/13/2024 11:00:34 AM • Heating &... • Answered 3 days ago
HP error code in bluestar split ac
Blue star inverter Ac HP error shown on display
4/10/2024 7:14:47 AM • Heating &... • Answered on Apr 10, 2024
2answers
Hello How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM • Heating &... • Answered on Apr 09, 2024
My azure split ac see the error code df sir pls give me solution for df error
Azure 1.5 ton splits ac old model e2 error
4/9/2024 12:44:23 AM • Heating &... • Answered on Apr 09, 2024
My Goldair gas heater ignites but the centre burner does not glow or come on. What could be the problem?
Blocked jets clogged with dust or dirt, blocked injector need a clean / service
4/8/2024 8:36:41 PM • Heating &... • Answered on Apr 08, 2024
Homebasix Olliscating parabolic heater how to reset
o reset your Homebasix Oscillating Parabolic Heater, follow these steps: Unplug the heater from the power source. Locate the Manual Reset Button on the heater. It's usually a small button or switch. Use a fireproof, non-conductive rod (such as a wooden stick or plastic tool) to press the Manual Reset Button. After resetting, plug the heater back in and check if it functions properly. Remember to ensure that there are no flammable objects within 3 feet of the heater and that it is placed on a stable surface.
4/7/2024 11:23:24 AM • Heating &... • Answered on Apr 07, 2024
Kolin window type aircon is turned on but has no display. What can this mean and how to fix?
https://www.fix.com/repair/appliance/air-conditioner/does-not-turn-on/
4/2/2024 11:36:49 AM • Heating &... • Answered on Apr 02, 2024
Chevrolet 1999 Chevrolet Tahoe LT Logo
12 questions posted
Top Chevrolet Heating & Cooling Experts
Paul Carew
john h
Are you a Chevrolet Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Chevrolet Heating & Cooling
Most Popular Question
when turn wheel left in 1999 chevy tahoe
  • Heating & Cooling
