20 Most Recent Purolator 5455455076: Ultra-Cell High Capacity HEPA Filter Questions & Answers
Here is a link to the blink codes if you ever need them again. It looks like you have a thermister that failed or the connection has become corroded. Your going to need to find it and check the connection or replace it.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.hitachiaircon.com/argws/html/helpingyou/en/AlarmCodes.pdf&ved=0ahUKEwiq-K__goLPAhXLPD4KHUARCwMQFggbMAA&usg=AFQjCNHYGrrhLgmTOJdADsQhCbYuVZGKkw
Heating &... | Answered 11 hours ago
You take it to an air conditioning specialist who can tell you what is wrong and how much it will cost to fix it.
With air conditioning units, there is almost nothing you can do yourself.
Heating &... | Answered Yesterday
The most common reason that your Air Conditioner compressor won't turn off is because a stuck relay keeping the circuit closed. You should have a service person take a look and replace the relay or circuit board. Depending on how old the unit is, it might be worth buying a new ac unit.
Heating &... | Answered 2 days ago
Go to Pep Boys or Advance Autoparts or a place like that.
Your issue sounds like either a bad "pressure switch" or that the unit is low on "Freon." Either of these problems will cause the compressor to start and run shortly then compressor cuts off, then and repeats itself.
From your description It really does Not seem to be a "bad board in that unit" because the compressor is starting up, even though the compressor is not staying on long enough to cool said area.
Purolator 5455455076: Ultra-Cell High Capacity HEPA Filter Logo
0 questions posted
Top Purolator Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
Are you a Purolator Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Purolator Heating & Cooling
Most Popular Question
causes wwk18crn1mj7 window unit
  • Heating & Cooling
