20 Most Recent
Mastercool 71475-SUPREME Deluxe Master Universal Hydraulic Flaring Tool Kit Questions & Answers
My Mastercool window evaporative cooler worked fine last summer. As I got it ready today, the pump turns on, OR the fan. If I turn on both, it shuts off. Either works by itself, but not together.
Saw several (but very limited) videos related to this online. All have indicated it as a problem with the control panel itself. I had a technician examine and that also was the conclusion with my own MC window evap not working. Fan would turn on briefly, go from high to mid to low on its own, then shut off. Lights woild also flash as it would toggle from each fan speed aling with oump going on then off on then off like crazy. I plugged the cable for the pump into an extension as indicated by one of thos very limited online videos and that has worked without any problems. My pump has been providing the needed water since doing that for hours. The fan blades however do not have a separate means to run without installing a control for the nlade speed it seems. So a delimna there. Changing the control panel costs about $100 for the part. Maybe the newer model part which runs $49 might work? The very limited videos that do nothing to show the process of how it’s done all show them installing their own control panel whether that is a turn switch or a thermostat system.
Matercool thermostat wont turn on drain pump
Condensate pumps dont work with the thermostat . The pump has an internal float switch that kicks the pump on when the water reach a high level. If the pump failed for any reason the safety swicht will turn off the ac unit to prevent any water overflow.
