20 Most Recent
Frigidaire FAC104P1A Compact II Room 10000 BTU Air Conditioner, Cools room sizes up to 490 sq. ft., Energy Efficiency Ratio 9.8, Smaller footprint, with the cooling capacity for medium to large room applications, Variable Speed Fan, 24 Hour On / Off Timer FAC-1 Questions & Answers
Window ac/heater freezes up when using the heater?
This is likely due to a lack of airflow. Make sure that the air filter is clean and that there are no obstructions blocking the air intake or exhaust vents. If this does not resolve the issue, you may need to have a technician come out and inspect the unit for any other potential issues.
Can't change temperature on AC
thats normal its showing ambient when you lower it the number will change to the setting and then will go back to show what the ambient temp as the room gets cooler the temp number will go down and shut off at set temp
