20 Most Recent Panasonic CU-S9NKU-1, Air Conditioner Outdoor Unit Questions & Answers
Panasonic CU-S24JKQ parts
We recommend you use the below link to locate an authorized distributor in your area. http://www.easylocator.net/search/map3/HVAC%20Distributor/product/HVAC/category/Distributor/ Hosted Store Locator Service EasyLocator net
4/14/2014 8:46:56 PM • Panasonic... • Answered on Apr 14, 2014
Panasonic cu-e12ckp5 timer light flashes constant
Press the "check button" by tip of a pen continously for 5 seconds. You should see error code starting with H.. or F.. on your remote control. Continue from there, googling the error codes.
10/29/2022 1:02:28 PM • Panasonic... • Answered on Oct 29, 2022
We have a Panasonic CU-A34BBP5 air con which starts up but won’t stay on. Error code F42
HI Duncan, Error Code F42 means the Outdoor unit P.C. B (NOISE FILTER) is faulty or connector ACN2 Enclosed is a link to 2 service manuals that may be helpful you. Good luck, JP https://www.manualslib.com/manual/1155827/Panasonic-Cs-A24bb4p.html#product-CU-A34BBP5 https://www.panasonicproclub.com/uploads/CZ/catalogues/cac/service-manual/CS-F50DB_service%20manual_mac0502037c2.pdf
6/15/2022 4:12:55 AM • Panasonic... • Answered on Jun 15, 2022
I am Having Panasonic VRF 10 HP with 10 INDOOR UNIT MODEL NO. U-10EA1E8 AS MY INDOOR UNIT GIVE ERROR CODE F27-01 ,OUTDOOR UNIT STARTS BUT THE FAN MOTORS DO NOT START ANY SOLUTION U CAN SUGGEST
Temp sensor, bad motor, bad control board…too complex you need help. Your outdoor unit will have a better diagnostic code to hopefully narrow the problem but this requires opening of machine.
4/22/2022 2:00:02 PM • Panasonic... • Answered on Apr 22, 2022
4answers
Installed Panasonic Bathroom heater/fan model FV-11VHL2. The heater turns on for a few seconds and then shuts off. Any idea why the heater won't stay on?
thermostat or or thermal cut off. I would take it down and return for another one, do not try fix this yourself. parts will exceed price..
12/14/2021 2:17:00 AM • Panasonic... • Answered on Dec 14, 2021
F95 error on Panasonic professional AC for server room
The F95 error code appears on Panasonic inverter air conditioners due to the overheating of the outdoor coil. It is basically, protection against the outdoor high-pressure rise. This problem usually occurs due to issues relating to blockages, a dirty condenser coil, cool mode, or low gas.
How To Solve F95 Panasonic Error Code? - Aircon Servicing
and more information and videos https://www.google.com/search?q=F95+error+on+Panasonic+professional+AC ..
12/1/2021 4:45:52 PM • Panasonic... • Answered on Dec 01, 2021
2answers
Panasonic inverter air conditioner error code h11 pls help
Assuming you have a mini split and not a VRF system (although it is possible the error codes are the same),the h11 code typically indicates a communications problem between the indoor and outdoor units. This could be due to loose or broken wiring, a bad connection at either end or possibly a bad communications board in either the indoor or outdoor unit.
10/11/2021 7:39:18 AM • Panasonic... • Answered on Oct 11, 2021
2answers
Problem with panasonic cu-s10hkh air conditioner outdoor cannot run
It is likely equipped with a temp sensor that only permits the fan to run when the compressor reached a certain temp. If the unit is short cycling then obviously there is a problem. Likely in that sensor. Good Luck. If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
7/28/2021 7:20:31 AM • Panasonic... • Answered on Jul 28, 2021
Need a filter for Panasonic CW-C101MU Air Conditioner
I searched the internet using https://www.google.com The site below is alleged to have the filter for that model: https://encompass.com/model/MSCCWC101MU
6/7/2020 9:27:20 PM • Panasonic... • Answered on Jun 07, 2020
On a Panasonic air conditioner split system cs-e12jkr is not turning on timer light blinking done a code check and H33 come up what can I do to fix this cheers
This error is: Indoor / Outdoor wrong connection Check that the wiring between the indoor and outdoor have not been crossed over, ie make sure that the same color wire connects the same terminal number on both the indoor and outdoor. After that, check that you are getting full supply voltage to the system. High resistance somewhere in the circuit may not provide sufficient power. Corroded isolator contacts or wire terminals for instance.
3/11/2020 3:53:19 AM • Panasonic... • Answered on Mar 11, 2020
What is error code h55 in panasonic floor mounted ac E28NFQ?
H55 error comes from the window that has not properly function to open, you must have off the breaker of the unit then, remove the upper window and check if the motor is not parallel to each both side, then return it and switch the breaker and turn on the unit
9/23/2019 2:44:00 AM • Panasonic... • Answered on Sep 23, 2019
Hi Sandra , Error Code F42 means the Outdoor unit P.C.B (NOISE FILTER) is faulty or connector ACN2 Enclosed is a link to 2 service manuals that may be helpful you. Good luck, JP https://www.manualslib.com/manual/1155827/Panasonic-Cs-A24bb4p.html#product-CU-A34BBP5 https://www.panasonicproclub.com/uploads/CZ/catalogues/cac/service-manual/CS-F50DB_service%20manual_mac0502037c2.pdf
6/25/2019 11:50:24 AM • Panasonic... • Answered on Jun 25, 2019
How to reset timer flashing CS-PC12MKH
That's indicating that an error has been detected and you need to put the remote into service mode to find out what the error code is. You will have to repair the fault before it will return to normal operation.
5/22/2019 11:38:41 PM • Panasonic... • Answered on May 22, 2019
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation. 2 Press the CHECK button on the remote control continuously for 5 seconds. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking) 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched, Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed. Diagnosis display Abnormality / Protection control Abnormality Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica tion > 1 min after starting operation Indoor fan operation only • Internal / external cable connections • Indoor / Outdoor PCB H14 Indoor intake air temperature sensor abnormality Continue for 5 sec. - • Intake air temperature sensor (detec tive or disconnected) H15 Outdoor compressor temperature sensor abnormality Continue for 5 sec. - • Compressor temperature sensor (detective or disconnected) H16 Outdoor Current Transformer open cir cuit - - • Outdoor PCB • IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance continuously - • Indoor PCB • Fan motor H23 Indoor heat exchanger temperature sen sor abnormality Continue for 5 sec. O (Cooling only) • Heat exchanger temperature sensor (detective or disconnected) H24 Indoor heat exchanger temperature sen sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor (detective or disconnected) H27 Outdoor intake air temperature sensor abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec tive or disconnected) H28 Outdoor heat exchanger temperature sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature sensor (detective or disconnected) H30 Outdoor discharge air temperature sen sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance continuously - • Indoor PCB • Ventilation motor H51 Nozzle lock abnormality 2 times occurance continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance within 30 minutes - • Indoor PCB • Fan motor H98 Indoor high pressure protection - - • Air filter dirty • Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro tection - - • Insufficient refrigerant • Air filter dirty F11 Cooling / Heating cycle changeover abnormality 4 times occurance within 30 minutes - • 4-way valve • V-coil F90 PFC control 4 times occurance within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance within 20 minutes - • No refrigerant (3-way valve is closed) F93 Compressor rotation failure 4 times occurance within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro tection 4 times occurance within 30 minutes - • Excess refrigerant • Improper heat radiation • IPM (Power transistor) F97 Outdoor compressor overheating protec tion 4 times occurance within 10 minutes - • Insufficient refrigerant • Compressor F98 Total running current protection 3 times occurance within 20 minutes - • Excess refrigerant • Improper heat radiation F99 Outdoor Direct Current (DC) peak detec tion 7 times occurance continuously - • Outdoor PCB • IPM (Power transistor) • Compressor Note: "O" - Frequency measured and fan speed fixed. The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller. Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
5/20/2019 7:44:36 AM • Panasonic... • Answered on May 20, 2019
Air swing not moving
This one is swing regulator
I need help
Its available or not
And whats the prince
5/14/2019 12:33:07 PM • Panasonic... • Answered on May 14, 2019
Panasonic CU-S9NKU-1, Air Conditioner Outdoor Unit Logo
2 questions posted
Top Panasonic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Heating & Cooling
Most Popular Question
panasonic cu s24jkq parts
  • Heating & Cooling
