20 Most Recent Miele S5980 Capricorn Canister Vacuum Cleaner with SEB236 Powerbrush Questions & Answers
I have a Miele Classic C1 Cat & Dog. Had to replace the motor. Now the motor is quiet but there is little to no suction through the hose. Some air comes thru the exhaust.
You have a blockage somewhere. The most likely place is in the brush head behind the brush or at the first joint to the metal tube.
Classic C1 Cat & Dog PowerLine - SBBN0
Miele https://www.miele.ca > Shop > products > detail > cani... High suction power - 1200 W; Optimum carpet care - electrobrush for intensive deep cleaning; Adjustable working height - Stainless steel telescopic tube ... $799.99 ,,
1/28/2024 2:54:26 AM • Miele Vacuums • Answered on Jan 28, 2024
Miele canister vac - foot pedal will not release
I'm assuming you have a canister with an seb236/34 power nozzle. The handle release pedals break all the time and would need to be replaced to fix your problem.
10/7/2023 4:52:16 PM • Miele Vacuums • Answered on Oct 07, 2023
I have a Miele S5980 vacuum cleaner that won't power on properly. Need help.
Possible electrical short in the reset switch.
8/17/2023 5:35:23 AM • Miele Vacuums • Answered on Aug 17, 2023
2answers
Miele s7210 light comes on,but doesn't run. no clogged hoses.
I have a Miele with a failed motor and it sounds if you have as well. The is nothing shown as a common, or known fault. Take it to your local Miele Service Centre for diagnosis and repair. https://www.google.com/search?q=Miele+s7210+light+comes+on%2Cbut+doesn%27t+run ..
6/4/2023 10:15:00 AM • Miele Vacuums • Answered on Jun 04, 2023
Miele Vacuum SEB 234/236 Roller Brush Issue
If the roller brush of your Miele vacuum SEB 234/236 only spins when you manually hold down the switch, it indicates that there is a problem with the electronic circuit or mechanical parts responsible for engaging the brush. This could be caused by a faulty connection, a broken wire, or a malfunctioning switch. It's recommended to have the vacuum serviced by a professional to diagnose and fix the issue.
2/14/2023 5:41:57 PM • Miele Vacuums • Answered on Feb 14, 2023
Miele Compact C2 Electro + Powerline. Can I fix the electrical connection between the hose and the beater head. It's spotty so the beater head action turns on and off with motion, randomly.
It may be worn carbon brushes in the beater head and yes it can be fixed. You can try giving the head a thump on the side to help seat the motor brushes.
1/27/2023 6:07:35 PM • Miele Vacuums • Answered on Jan 27, 2023
My Miele C3 cat/dog won't adjust off of the min power setting. 6 years old, out of warranty, light use.
It sounds like there may be an issue with the power control system on your Miele C3 cat/dog vacuum. Here are some troubleshooting steps you can try:
  1. Check the power control switch: Make sure that the power control switch is functioning properly and that it is able to move freely through all of the power settings. If the switch is stuck or damaged, it may be causing the vacuum to remain on the minimum power setting.
  2. Check for debris in the power control system: Debris can sometimes accumulate in the power control system and cause it to malfunction. To check for debris, turn off the vacuum and unplug it from the electrical outlet. Locate the power control system and use a small brush or compressed air to carefully clean it.
  3. Check for a clog in the hose or suction path: A clog in the hose or suction path can cause the vacuum to lose suction and remain on the minimum power setting. To check for a clog, remove the hose and use a flashlight to look for any blockages. If you find a clog, use a broom handle or similar object to carefully remove it.
If these troubleshooting steps do not resolve the issue, it is possible that there is a problem with the power control system or another internal component of the vacuum. In this case, it may be necessary to have the vacuum repaired or serviced by a professional.
1/4/2023 11:31:08 AM • Miele Vacuums • Answered on Jan 04, 2023
2answers
My Miele Twist vacuum will not lock into the upright position. Also I sucked up a tassel from a throw pillow and have a clog. I took off the little clean out plate on back...it isn't in that par
Hi, to find that repair manual that you've requested and fix your vacuum so it can move into upright position, you can ask Miele to email you the manual by calling them at 888-996-4353 Thank you.
10/21/2022 3:36:19 AM • Miele Vacuums • Answered on Oct 21, 2022
Why is my Miele upright vacuum making a high pitched noise
clogged--belt slipping--motor failing
8/23/2022 12:08:19 PM • Miele Vacuums • Answered on Aug 23, 2022
2answers
Why does my miele vaccuum cleaner power brush lose power when i push it forward?
It loses power? Do you mean the brush roller does not spin or do you mean there is a loss of suction? Or does the vacuum shut off? I interpret this to mean no suction. That implies no air flow. https://bestsearchadvisor.com/miele-vacuum-troubleshooting-problems/ Lack of suction suggests either a blockage OR an air leak. If a canister is not properly seated, a gap offers air leakage. If there is a leak in the hose, again, there is a loss of suction. A hole in the hose requires hose replacement. If this problem is not one of loss of suction but rather loss of power in the brushes, there are other considerations, such as a build up of long fibers in the roller. https://howtofixit.net/miele-vacuum-troubleshooting-guide/ Alternatively, if the brush is failing to spin, the motor for it may have failed even though the suction continues to work. If there is a loss of all power when you push it forward, perhaps there is a problem with the cord, a breakage where movement breaks the power going to the vacuum. Here is a link to Miele's own troubleshooting page: https://www.mieleusa.com/c/troubleshooting-159.htm
7/3/2022 10:37:10 PM • Miele Vacuums • Answered on Jul 03, 2022
My Miele s8 cat and dog vacuum dust compartment keeps filling up with dust and cat hair
I see this all the time. The red or blue bag holder has either started to bow or it's legs aren't seated on the top of the little depressions. Check that and when you fit new bag remove the hose and check the little door on the bag is open and not closed if it's closed all the rubbish will fill the bag container rather than the bag. If this if the case buy new bag holder common problem.
5/5/2022 3:45:39 PM • Miele Vacuums • Answered on May 05, 2022
Miele upright dynamic U1 dog and cat vacuum
Air way probably needs cleaning and it is not producing a vacuum.
4/25/2022 5:24:09 PM • Miele Vacuums • Answered on Apr 25, 2022
Miele SKCR3 how to open vacuum cleaner
Slide the lever on top of the dirt to the side, lift the cup up slightly, and pull it straight out of the vacuum. On most models, the lever will slide to the left. Disassemble the dirt cup by popping the plastic top off the cup. img-20220425-wa0002-undefined-undefined-0.jpg
4/25/2022 6:48:34 AM • Miele Vacuums • Answered on Apr 25, 2022
How to install a miele vacuum cleaner S300 series cord reel rewinder
There are a couple of videos that might help and links where to purchase.
12/31/2021 3:51:13 AM • Miele Vacuums • Answered on Dec 31, 2021
Miele S5980 Capricorn Canister Vacuum Cleaner with SEB236 Powerbrush Logo
1 questions posted
Top Miele Vacuums Experts
john h
Ngoro
jws1013
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Miele Vacuums
  • Miele Vacuums
Most Popular Question
replace belt miele seb236 powerbrush
  • Vacuums
