20 Most Recent
Bissell 1716 SpotLifter PowerBrush Questions & Answers
My bissell spot lifter model 1716 won't spray water at all, how do i fix this?
ok - this works even though it probably isn't the "best" solution. Unclog the input and output nozzle ares with a pin. The input area (behind the solution) was my clog problem - I put 2 or 3 drops of CLR into the hole, waited 5 minutes, then primed the trigger. This unclogged it! Fill the tank with a 1:1 ratio of white vinegar and warm water. Insert tank into unit and spray out the contents into the sink. This will eliminate any leftover CLR residue and clean the nozzle thoroughly. For the intake (suction part of the tank) I just rinsed through the lines with the vinegar mix and it seemed to unclog the rest. These things are a pain to take apart and if you break any pieces you'll be stuck - replacement parts have been discontinued for older models.
My Bissell little green machine has no suction at the hose end.
If your Bissell Little Green Machine has no suction at the hose end but good suction underneath the dirty water tank, try these steps: check for clogs in the hose and attachment, ensure the tank and filters are properly seated, test without an attachment, inspect for damaged hoses or seals, clean the machine, and run hot water through the hose. If the issue persists, contact Bissell customer support for assistance or consult your user manual for specific troubleshooting steps.
Bissell pro 2x healthy home carpet shampooer wheel not spinning
Hello Jeanette The answer from 'Rushikesh' that you thanked is from an Indian Artificial Intelligence Answer Bot. The site has been plagued with them for a month or so. They all answer in the same format 1. Repeat the Question. 2. Give five GUESSES to fix. 3. Tell you to consult a professional! From a real person : You need to change the drive belt, simple as that! If you turn the machine over an turn it on, if you carefully put your hand of the brushes, you will find you can stop thee brush from spinning. That shouldn't happen. ..
BISSELL powerforce helix silver piece fell out? 2191 not compact
It sounds like the small silver piece that fell out of your BISSELL Powerforce Helix may be the motor brush. The motor brush is a small, spring-loaded carbon block that makes contact with the motor to conduct electricity. If the motor brush falls out or is not installed correctly, it can cause the motor to make a loud, high-pitched noise.
To fix the problem, you should locate the motor brush and try to reinstall it. The motor brush is typically located near the motor on one or both sides of the vacuum. You may need to consult the user manual or contact BISSELL customer service for specific instructions on how to access and install the motor brush.
If the motor brush is damaged or missing, you may need to purchase a replacement motor brush from BISSELL or a vacuum repair shop. Once you have replaced the motor brush, the high-pitched noise should go away and the vacuum should operate normally.
How do I replace the upright locking foot pedal on my Bissell 3760-4
Replacing the upright locking foot pedal on a Bissell 3760-4 is a fairly straightforward process. Here are the steps you can follow:
- Turn off and unplug the vacuum cleaner.
- Lay the vacuum cleaner on its side so that you can access the bottom of the machine.
- Locate the locking foot pedal and use a screwdriver to remove the screws that hold it in place.
- Once the screws are removed, gently pull the old locking foot pedal away from the vacuum cleaner.
- Take the replacement locking foot pedal and position it in the same spot where the old one was removed.
- Use the screwdriver to attach the replacement locking foot pedal with the screws you removed earlier.
- Test the new locking foot pedal to make sure it works properly and holds the vacuum cleaner in the upright position.
- Once you are satisfied with the new locking foot pedal, flip the vacuum cleaner back over to its normal upright position.
- Plug in the vacuum cleaner and turn it on to make sure everything is functioning properly.
With these steps, you should be able to successfully replace the upright locking foot pedal on your Bissell 3760-4.
My height adjustment on my new bissell power force helix tirbo rewind vaccum wont adjustmy height adjustment dont go up and down
If the height adjustment on your Bissell PowerForce Helix Turbo Rewind vacuum is not functioning properly, there are a few things you can try to fix it:
- Make sure that the height adjustment lever is being pressed down all the way. Sometimes the lever can get stuck in the "up" position, which prevents the height adjustment from working.
- Check the height adjustment mechanism to make sure it is not damaged or obstructed. This may involve removing the vacuum's dustbin or base plate to access the mechanism.
- If the height adjustment lever and mechanism are functioning properly, the problem could be with the vacuum's belt. The belt is responsible for driving the height adjustment mechanism, and if it is stretched or damaged, it may not be able to move the mechanism properly. In this case, you may need to replace the belt.
- If none of these solutions fix the problem, the vacuum's internal hardware may be faulty and will need to be repaired or replaced. You may need to seek the assistance of a professional for this type of repair.
