20 Most Recent
Singer Touch and Sew Bobbins Questions & Answers
Singer Touch and Sew 756 feed dog gear replacement
DON'T cut lumps out of your machine. There will be a sequence you use to remove the parts you need to access to the gears more easily. The Youtuber you referred to sounds like they have zero knowledge when it comes to these older style machines.
'Note' Some of the gear mount nuts are on a "Reverse" thread meaning you turn them the 'wrong' way to get them off.
My limited knowledge is more on the much older hand crank and treadle machines.
Try the Youtube link below for a channel called 'Andy Tube'. He has a good reputation for correct repair methods. The link is for a 758 but they're both Touch and Sew machines.
You could also try the Facebook group 'Vintage Singer Sewing Machines' as they have loads of knowledge about loads of different machines.
https://www.youtube.com/watch?v=zxd5hKjGBlE
All my decorative stitches are comming out straight
it sounds like something has happened to the cam gears thatdo the decorative stitches, which means the sewing machine needsto be checked..but before you have the machine checked,, make sure all the dial that are used for decorative stitches are at the right settingone missed setting can cause a lot of problems
