20 Most Recent
Dirt Devil Dynamo Pet Bagless Upright Vacuum Questions & Answers
I have model#UD40350 total pet compact. The lower vacuum brushes don.t turn.
Hi! It sounds like you have a broken or stretched belt. The belt controls the brush roll. If you are using the vacuum on carpet, you need the brushes to spin to agitate the carpet fibers. Below are step-by-step instructions on how to replace your belt. I have also included a link to the instruction manual if needed.
1. Lay cleaner flat and flip to expose nozzle base. To remove nozzle guard, use Phillips screwdriver to remove the screws.
2. Lift and remove brush roll and dispose of old belt if you see one.
3. Slide belt (style 19) onto motor shaft.
4. Place new belt on area of brush roll without bristles.
5. With new belt in place, pull and slide brush roll into nozzle making sure that the brush roll end caps are in the correct orientation.
6. Replace all screws to replace nozzle guard.
http://dirtdevil.com/file/898/
Hope this was helpful!
What is the filter bag number
type G
look on amazon or copy and paste
https://www.amazon.com/dirt-devil-model-103-bags/s?k=dirt+devil+model+103+bags
Dirt devil power stick lite edge to edge
See picture for details. It is unnecessary to remove the roller brush to clean it. The picture will show you how to do but not all vacuum cleaners will have a line where to cut. In this case, you can still use a utility knife just be more cautious where your cutting and not too deep. Make your cuts on both sides of the roller.
If you still need to pullout the roller brush, don’t worry too much about pulling it out strait. Pull one end slightly, do the other end in the same way until it comes out.
