20 Most Recent
Hitachi CV-SH18 CYCLONIC HIGH POWER VACUUM CLEANER FOR 220 VOLTS Questions & Answers
How do I clean Hitachi
The easiest way is to take an air compressor and blow out the dust internally first through all of the vents. Then just take a damp cloth with a water/soap mix or some cleaning product that can be used on the plastic and just wipe down the outside. I recommend using the air compressor outside. If you don't have an air compressor available to you, then the cans of compressed air will work too.
Let me know how this works out for you.
Benjamin
How do i fix a vacuum line hose on a car that's been cut?
Alot depends on the type of hose. There are plastic hoses and rubber hoses. Generally you can use a smaller plastic connector to connect two rubber hoses together and visa versa, Make sure it is a snug fix. You could also use an adhesive to keep it together.
3/31/2024 3:39:13 PM •
Vacuums
Answered
on Mar 31, 2024
