20 Most Recent
Fisher Paykel Fisher & Paykel AquaSmart WL42T26DW1 25" Top-Load Washer with 3.1 cu. ft. Capacity, 7 Wash Cycles, Load Sensing, Dual Washing Modes, 3 Dispensers, Auto-lint Disposal, Smart Drive System and LED Control Panel Questions & Answers
Fisher and paykel aquasmart fault 235
Try cleaning the INLET and the outlet valves, it is possible that the filters are blocked. If not check the wiring harness from the panel, check for moisture within the panel, if so use a dryer to warm off and test. Please estimate before any parts are replaced.
Gorenje washing, why does it stop with 1 left ?
Your NOT suppose to "Program anything". Machines are kinda like people. After they work, they need "some" time to rest. Your machine (And Mine) all do this. Next time leave it alone, the minute will count down and it will automatically shut off. Question? You actually stood by the machine and watched the entire cycle? Was there another problem that motivated you to do this? Like your clothes were still wet or water still in the tub? If you need further help, reach me via phone at
https://www.6ya.com/expert/steven_b77d19396bfe2249
I want to bypass lid lock
It would be innapropriate to recomend the removal of a safety device.
I would repair it, not remove it.
Why does my water won't stop filling?
A few possible causes:
Blocked Water Level Switch: Most top-loading washing machines utilize a pressure switch to tell the water when to shut off during a wash or rinse cycle. If the tube becomes blocked with minerals from hard water or if the switch itself goes bad, the water will never shut off.
Bad Water Valve: Valves at the points where the hot and cold water hoses enter your washing machine control the flow of water into the machine. If these valves become stuck open, or if their seals become lost or compromised, the water will continue to flow into the machine.
Faulty Controls: The controls might fail to acknowledge the input from the pressure switch and never advance from one cycle to another. In some cases, this is a voltage problem, while in other cases the controls themselves are bad and would need to be replaced.
If you've already cleaned and cut the ends of the tube going to the level sensor and the issue persists, it might be best to consult with a professional appliance repair service. They can help diagnose and fix the problem accurately. Please remember to turn off the water supply and unplug the machine before attempting any repairs.
Error code in JCB 437 loader Q0195 any have a clue?
on a loader its most often fluids or leaky compresion
masters or slaves or the distribution
and or it need bleed or and filled etc {not easy}
you need a tech it needs a fluids check
could be just a bad filter...
What year is my Elite 1778t 611379 thank you
The Elite T Series guitars were made in the USA and are known for their exceptional sound engineering and craftsmanship.
Unfortunately, the exact manufacturing year based solely on the serial number is not provided in the available information.
OVATION GUITARS
My washer is top lip, now the washer stop spinning. How to fix it please?
'top lip'? you mean a top load?
If it washes okay and the motor runs, it is likely the capacitor on the motor that does spin has failed,
Or the motor control board has failed.
Or the timer controller / main board has failed.
FULL 'make model (what it is)' in all questions please, first 3 words
